rob_lewis
rob_lewis UberDork
12/31/23 4:32 p.m.
Engine flush was amazingly clean. I expected it to be darker. Fresh oil and I have 40 psi at idle, which is right in the middle of the gauge. Lifter is still noisy, so I'll need to keep a watch on that. Two years ago, it would quiet up after driving for 5 minutes. Hopefully it'll do the same this time. Plus, I'll go back to full synthetic after I run with this oil for a bit. That might help. I used dino oil for this round since I was flushing it.
-Rob
ShawnG
ShawnG MegaDork
12/31/23 4:59 p.m.
I had an old IHC 345 with noisy lifters. I'd toss in a qt of ATF 100 miles before an oil change.
Lifter tick went away after a couple cycles of that.
Cousin_Eddie (Forum Supporter)
Cousin_Eddie (Forum Supporter) SuperDork
12/31/23 5:01 p.m.
Is your PCV system functioning ? You really seem to have an unusually bad case of sludge for one of those engines.
rob_lewis
rob_lewis UberDork
12/31/23 5:39 p.m.
I think the sludge is because it's running rich.  I don't have any codes, but I think my coolant temp sensor is bad because when I fire it up on cold startup, it idles like normal instead of idling high and then dropping down.  I have a new sensor on my bench, but haven't gotten to it yet as I've been chasing other things and just been busy until now.  It's next on my list as a "to do" and will probably do the water pump at the same time as it's weeping.  Again, just trying to organize the top items first.
-Rob
81cpcamaro
81cpcamaro SuperDork
1/1/24 3:51 p.m.
Those year 4.3s don't have adjustable rocker arms, so if the lifter is weak/failing, it would make noise. Mine (1999) has rocker tapping at cold start, but goes away with oil pressure and warming up. The offending rocker should be a bit looser than the rest.
NlSsVqzOlBuOUieSEdp4swhSlxClLKl1AKTxvcTlY9jxaMEc3j9cNaASVfAPq7g6
