sealy
sealy None
5/30/14 7:41 p.m.
Instructions call for fan power to come directly from the battery terminals which are in the trunk. Do jumper blocks preform this task effectively? Thanks!
bgkast
bgkast SuperDork
5/30/14 7:44 p.m.
Assuming you have a front engine car I would use the big positive wire to the starter.
Slippery
Slippery HalfDork
5/30/14 7:46 p.m.
What car is it?
BMWs have a fat battery wire going all the way to the engine bay. Use a relay.
novaderrik
novaderrik PowerDork
5/30/14 7:59 p.m.
the mustang that you have as your avatar?
assuming it's wired similar to stock: run it to the starter solenoid, where the power for the rest of the car comes from.
tr8todd
tr8todd HalfDork
5/30/14 8:06 p.m.
Run a decent sized wire from the battery to the engine bay. Install a distribution block so you can pull power for anything you want off the block. Don't forget to install fuses on everything. If you want to be slick, add another distribution block for switched power using a relay and signal from the ignition.
Kenny_McCormic
Kenny_McCormic UberDork
5/30/14 8:30 p.m.
How many amps does it pull?
You can also use the alternator wire as a convenient power junction if the starter is hard to get at, assuming it's not a "smart" alternator.
UQgVp2mKqLUxwhw2fANEX9lfpFBR4Y3TeYJx2A01KOOpAwprgtV4szCPcbKA8jkG
