Per Schroeder
Per Schroeder PowerDork
8/27/20 10:00 a.m.
Installing new suspension bushings is a very labor-intensive job, but one that will pay off with a more precise suspension and improved handling. Stock rubber bushings are biased toward ride comfort and vibration reduction. Replacing these components with ones made out of stiffer material, like pol…
bumpsteer
bumpsteer New Reader
12/12/22 11:22 a.m.
In my opinion, properly supporting the part you're pressing is about 80% of the battle when pressing bushings if you already have a proper press to do it with. Often the control arm or subframe the bushing is attached to is awkward and doesn't have good square surfaces to react tons of force off of.
Also would like to note, if you can at all avoid having to burn out the bushings, it usually takes longer and makes an absolute mess of things.
300zxfreak
300zxfreak Reader
12/12/22 2:22 p.m.
1/4 stick of TNT will usually suffice.......
300zxfreak
300zxfreak Reader
12/12/22 2:23 p.m.
Or, a little shot of liquid Nitrogen and a cold chisel.....
Turbine
Turbine Reader
12/12/22 3:02 p.m.
In my experience, replacing bushings has involved a MAPP gas torch, hammer, a chisel or old screwdriver, and lots of swearing.
Noddaz
Noddaz PowerDork
10/1/23 6:55 p.m.
And if you are lucky, the chrome sockets you are using to press the bushing out or back in won't shatter into shrapnel.
earlybroncoguy1
earlybroncoguy1 Reader
10/1/23 8:42 p.m.
In reply to Noddaz :
Use impact sockets - they're thicker wall and stronger.
Hole saws work well to chew through the rubber of old bushings. Once you've got the rubber out and can get to the outer shell of the old bushing, use a chisel to knock it out of the suspension part.
HvkOK7bUL3CEKAF3T4dr2Z1BliO2rKlePlNAEAtgnA18LOj4aOV4iFZWgGZdjLT5
