We are parting out an 84 F150. The seller claimed that it had a 351 but we believe that it has a 302. How to tell the difference?
wclark wrote: the 351W has a 1-3-7-2-6-5-4-8 firing order versus the 1-5-4-2-6-3-7-8 found in the 289/302.
That firing order should be cast into the top of the intake manifold.
NOHOME wrote: 302 Block. Note distributor hole.351 Block. Note sunken distributor hole.
Thanks, I've never noticed that before.
The firing order can vary based on what cam is in the engine so don't count on what is cast into the intake. If someone changed the cam... who knows?
NOHOME had it, look at the blocks, an easy determination using those pictures.
The water pump deck height is the easy way to tell. If the head is sitting on top of the water pump its a 302 or 289...or 260.
