Carl Heideman
Carl Heideman
3/24/23 8:00 a.m.
In the hierarchy of automotive dreads, rust repair and wiring rank near the top for most people. Rust repair we get, but wiring doesn’t have to be a nightmare. After all, a wire just goes from one place to another. How hard can that be?
The problem is there’s always more than one wire.…
JG Pasterjak
3/24/23 11:00 a.m.
YOU CAN DO BETTER THAN THIS!
[narrator, watching me do wiring]: It turns out, he could not do any better than this.
gumby
gumby Dork
3/24/23 11:12 a.m.
Both timely and appropriate as I prepare to make better the American Autowire harness in my own Type65.
Looking forward to the future installments, and thank you for sharing your knowledge and experience
3/24/23 1:18 p.m.
Thus the current Colin conundrum.  I want to do better than this.  It requires a crazy amount of planning, because wiring harnesses look like that when things are added after-the-fact.
The
The Dork
3/24/23 11:59 p.m.
I would welcome some tips on thining out  thee harness of my e36 track car, just want push button start, brake lights, fuel pump etc.... thanks in advance, the
3/25/23 12:59 a.m.
In reply to The :
The slow but sure way I have been doing it:  Identify a connector you do not need, cut the connector off of the wires, remove the loom (if it is like the R53, the loom is cloth tape wrappings) and resecure the harness with a few zipties at strategic points, extract the wiring from the loom by PUSHING to find where it wiggles.  Continue until you get to a splice (cut at splice), ground junction, fuse box, or wherever else it terminates.
You will need to re-snug the zip ties on occasion as you thin the herd.  That is why zip ties are nice.  Get big bag and be generous with their use.
Here's a pic I took while I was about a quarter of the way through my current progress.  Almost all of the wires running down the tunnel area are gone except for about seven or eight, for the power mirrors.  Likewise a lot of the ones on the right, quite a few on the left, and I even got it to the point where I was able to re-loom the wiring in spots.
The
The Dork
3/25/23 9:48 p.m.
Pete, thanks for the tip, thats kind of the way I was thinking, take out a wire, does the car still run, yes/no go or stay. thanks, the
DaleCarter
DaleCarter New Reader
3/26/23 1:40 a.m.
     The "physical" aspects of wiring... proper crimping, gauges, connectors, looming, routing, etc are great and this article is addressing that part of the job. Will you get into designing a wiring topography that isolates data circuits and their power supplies from the "noisy" side of the car that carries fan motors, ignition systems,e tc ? Also, proper grounding is crucial.
     I bought a Panoz GTS that had been a full-time race car for about 20 years and, along the way, "Race day" repairs had been made to the wiring harness. When I pulled the dash tins off, revealing a bit of a rat's nest, my coach and friend said, "You can just put that right back and walk away", but I knew I could never unsee that. The last thing I wanted on my mind at 165 MPH entering 10a at Road Atlanta was "Man, that wiring is a mess". :-)
      I rewired the entire car from the firewall to the rear bumper, removing old, broken circuits, adding a rain light, a new switch panel and all the "oddities" from two decades of repairs made under the time pressure of getting back into the race.
     Proper wiring, with proper devices and materials, gives me a real peace of mind on track, plus elevates my knowledge of the car.
russelljones48
russelljones48 New Reader
1/8/24 8:49 a.m.
I have created my own mess.  I wasn't happy with my FFR roadster set up as it came from Factory Five so I installed a good aftermarket generic 20 circuit harness.  I'm now trying to get that looking like the pics on the boards and not having any luck.  So, my fallback position is to sort bundle and remove the excess.  It's this last piece that is driving me nuts.  What to cut? where to cut? Should I be ruthless and eliminate wires that I could possibly need in the future...  ?#*#?*!?   HELP
Jesse Ransom
Jesse Ransom MegaDork
5/17/24 6:41 p.m.
I don't suppose you guys have the order from your "kit" from Terminal Supply sitting around as an example BOM?
RacingComputers
RacingComputers Reader
5/18/24 5:52 p.m.
We have found that if you draw out what you want on a single piece of paper, then start removing what is not need in the harness, it goes rather wekk.
YRMV
RonB001
RonB001 New Reader
9/15/24 8:52 p.m.
A trick I picked up from a Formula SAE book a few years ago:
For developing the harness, use twist ties instead of zip ties.  That way, when you inevitably need to move or change something, you can just untwist the tie and make the modification, without having to cut and replace the zip tie.
Then, when you're done changing, you can replace all the twist ties with permanent zip ties.
Another tool recommendation:
Get one of the zip tie tensioner/cutter tools.  In addition to applying consistent tension, they also cut the excess flush, so you don't have little sharp bits all over the place to slice the back of your hands.
tomtomgt356 (Tommy)
tomtomgt356 (Tommy) Reader
9/16/24 8:25 a.m.
Ditto. I have a trailer and track car I need to rewire and would love you use something better than the random cheap Amazon/HF/WM connectors I picked up over the years that never seem to work right.
Carl Heideman
Carl Heideman
9/16/24 10:32 a.m.
I'll try to put something together in the next week or two. Since the story was first written, I've also found some better terminals with double crimps--one on the wiring and one on the insulation for stress relief. Goodspeed Motoring has a good selection. I really like the Dephi 12085271 crimping tool for these types of connectors. I got mine from Mouser
alfadriver
alfadriver MegaDork
9/16/24 10:54 a.m.
There are companies that sell the original pins that go into connectors.  As a matter of fact, some of them will send you "engineering samples" that could populate your entire harness.  I did that when I rewired an Alfa, using the original connectors to hold the pins.
One other thing I would add to harnesses is some kind of cover.  Some of the covers are ugly plastic, but that looks better than you trying to find a short when it wears through to touch the body.
NorseDave
NorseDave HalfDork
9/16/24 1:19 p.m.
In reply to alfadriver :
I'm a big fan of this stuff:
Wrap-around sleeving
It looks nice, neat and professional, but since it's split lengthwise, if you need to add a wire or two to your harness, it's not a problem.  Obviously it does not seal to the elements, but there aren't many (any?) factory harnesses that are.
Jesse Ransom
10/29/24 5:35 p.m.
In reply to Carl Heideman :
Thank you, on both counts! (all three?)
In reply to NorseDave :
Well that stuff certainly looks nicer than the corrugated black plastic! McMaster FTW again...
Ranger50
Ranger50 MegaDork
10/29/24 5:55 p.m.
If I had the money, I'd have Devin Vanderhoof wire up my ride. Check his videos out on the tubes of you.
10/29/24 6:50 p.m.
In reply to Jesse Ransom :
You can buy it from Summit Racing far cheaper.  I buy many rolls from them.
I love it because the wires don't tend to fall out like with split loom.  With split loom you really need to do a wide wrap with tape to keep the wiring together inside the loom, and split loom can wear through.  Or degrade with heat if it is on or near the engine.  That braided stuff is very difficult to abrade through and the wires won't fall out, and seems to be a lot more temperature resistant.
Downside, I have yet to find a good easy fast method for putting it on.  It sucks but it only sucks once.
Split loom trick for keeping the ends on: wrap the wiring with electrical tape where the end of the loom will be, then while wrapping, slip the loom over the wires with the tape coming off through the split, then keep wrapping the tape over the loom out to the end.  This is how the OEMs do their harnesses with split loom.
Jesse Ransom
1/6/25 7:02 p.m.
In reply to Pete. (l33t FS) :
Are you getting the Summit brand, one of the fifty-twelve others they carry, or does it matter? Okay, I'm going to trust my gut with "not Dorman..." Was just checking Summit's site and was overwhelmed by choice...
I'll say this for McMaster-Carr; you may not get to choose brands, but a lot of the time it feels like that's just weeding out the bad ones, even if you do pay for "not the cheapest kind."
1/6/25 7:10 p.m.
Summit brand because they sell it in bags on the store shelves, no need to wait in line for them to pull your order.
Their retail store is mostly set up like online ordering, in that aside from some sundries on the shelves like some fluids and paints, you order the parts, then pay for them, then wait at a different counter for them to pull the parts for you.  That's for things they have in stock at your location, seems like a lot of things are either in Texas or are drop shipped from the manufacturer, like the .156 wall Allstar threaded tubes that I needed to re-engineer a certain car's front suspension.
Jesse Ransom
1/6/25 7:14 p.m.
Oh, sure, rub my nose in that Summit proximity... cheeky (though I think you more than pay for it in rusty fastener karma)
It takes a while longer when the counter I'm waiting at is in my kitchen.
Anyhow, thanks for the tip!
darkbuddha
darkbuddha HalfDork
1/7/25 2:46 p.m.
I'm deeply and heavily challenged by doing any wiring, even installing a pre-made loom from American AutoWire in my '70 Mustang, but I don't quite know why really except when I don't understand the circuit (like how it works), I get completely bogged down and overwhelmed. Honestly, seeing it as presented in the article, I at least feel better about how to go through the process better.
zvGuQEZqLsFtk6OTFUAaOxfDecVh2fn595znqZGRr1DaNZ2mtOKpr11iGEjbbMw9
