HunterBenz
HunterBenz None
10/31/13 5:52 p.m.
I have been looking into hydroboost brake systems trying to figure out some particulars and can't seem to get much info on pump requirements as far as pressure and such. I am building a 1972 Mercedes and an planning out a lot of things. I can't seem to figure out what kind of additional requirements a hydroboost system will add to a PS system. Anyone have any knowledge on this?
I don't know much about the abilities of the Mercedes pump, but I am not worried not opposed to putting a different pump on the car. There are also suspension pumps and such I can easily get to work.
I am using a Mercedes V8 and that will not change. Aside from not wanting to use a vacuum booster, I also want to move the hydro boost inside the cab. I have a buddy that did this on a rock crawler using a lever system and it works well. Any reason why levers might be bad for a raceish car? Other than more bits to fail.
Thanks for any info.
Jaxmadine
Jaxmadine HalfDork
10/31/13 8:42 p.m.
Look at part numbers for the chevy trucks. If its the same for a hydroboost model, I dont think the pressure matters much
curtis73
curtis73 UltraDork
10/31/13 10:57 p.m.
Power steering pumps make up to 3000 psi. I think the pumps are the same, but hydroboost vehicles get an extra PS fluid cooler.
novaderrik
novaderrik PowerDork
10/31/13 11:16 p.m.
my T Type has a factory installed hydraboost and no extra cooler..
HunterBenz
HunterBenz New Reader
11/2/13 3:57 p.m.
I will have to look up some of the part number info, not sure why I did not think of that. Thanks gents.
stan_d
stan_d Dork
11/2/13 9:05 p.m.
Why not run a larger master cylinder. And do away with boosted brakes.
oldtin
oldtin UltraDork
11/2/13 10:17 p.m.
I added hydroboost brakes to an old ford bronco with big tires. I pulled the hydroboost unit from a newer chevy diesel 2500. The most difficult was adding custom high pressure lines with metric fittings on one end and sae/npt (I forget now) on the other end. Some older caddys, lincolns and big mercuries have hydroboost with standard threads instead of metric. I did add an in-line cooler.
cfUEyOEJ1y0MFXHKE1cy7pkgex5B44DvL6BiMuIonwohMrf2K7MeWlXcBeIBsESP
