roninsoldier83
roninsoldier83 HalfDork
6/1/24 3:03 p.m.
So, my beloved Laguna Blue Pearl AP2 Honda S2000 has suffered from a plethora of paint chips for years- with most of them being on the OEM aluminum hood. Surprisingly, there are almost no chips at all on the (urethane) front bumper. There are also a few on the (not sure if they're aluminum or steel?) front left fender, but most of them are on the hood. I didn't count them, but there were likely ~50 paint chips on the hood.
I actually have a bottle of OEM Honda touch up paint- I've used it in the past, but it's resulted in splotches of slightly darker paint that almost look worse than the paint chips themselves. So, I've only used it sparingly.
I'm pretty confident that ~95% of these paint chips are the result of driving back and forth to autoX events (mostly on I-25, which was under construction for years).
I finally got tired of looking at them and decided to scour the Internet in search of a solution; to which the fine folks on Reddit led me to Dr. ColorChip.
I can't hardly believe how easy it was to use and how much of a positive difference it made! I truly regret not taking a before photo to demonstrate the difference. My wife acted as my assistant today and we were both shocked at the transformation- you would never believe this hood had ~50 paint chips in it, just an hour or so prior:
At first, I was nervous, as the color looked so much darker than my OEM paint... but my fears were unfounded. The process was super simple:
1. Clean the area you want to paint.
2. Dabble just a bit of paint onto/next to the chip (they give you a few brushes).
3. Use the soft rubber squeegee (they give you 2 different sizes of them) or your thumb to drag the paint across the hole, flattening the paint in the process - this will smear it all over making it look terrible, but don't worry, there's method to the madness.
4. Wait for the paint to dry (3-5 minutes).
5. Use their SealAct solution- this will clean up all the splotches. They recommend you use their supplied absorbant cloth and the palm of your hand, rubbing it softly until the excess paint comes off. In the end, this just leaves paint inside the rock chip hole- all paint surrounding it goes away, leaving it looking clean as can be.
6. Use a microfiber cloth (supplied) to buff the areas treated until they shine (very easy).
There's more in the kit that's not pictured (used clothes and nitrile gloves), but I ordered the Squirt 'n Squeegee Plus Kit:
After filling ~50 holes, I would say I used roughly ~20% of the SealAct, so I still have a ton left if needed in the future.
I'm mostly sharing this for people that have never heard of Dr. ColorChip. I'm not affiliated with Dr. ColorChip in any way, shape or form. I didn't receive any discount or payment from them, I paid full price and would gladly pay it again. With shipping I think the whole kit cost me $75 or so.
If you have a bunch of rock chips that are driving you crazy and don't want to pay for a respray, this whole process was relatively inexpensive, simplistic and highly effective. Yes, if you look very closely, you can still see evidence that the rock chips existed (they're ever so slightly darker than the rest of the paint, but this might change when cured), but from 3-5 feet away, the car no longer looks like I was following a leaking sand/gravel truck across the country. Now the only noticeable spots on the car are on the left fender where I previously used OEM Honda touch up paint- after using Dr. ColorChip, I'll likely never bother with OEM touch up paint again.
Just figured I would share my experience.
WonkoTheSane
WonkoTheSane UltraDork
6/1/24 5:06 p.m.
Thanks for sharing, and I wish you got before pics as well :)
roninsoldier83
6/1/24 6:41 p.m.
In reply to WonkoTheSane :
Honestly, I didn't expect how well the results were going to turn out- I had low expectations after using the OEM stuff- otherwise I probably would have taken a quick photo beforehand!
As mentioned above, thus far, the rock chip holes are slightly darker than the OEM paint, but you have to get fairly close and look for them- whereas the (clearly white) rock chips stood out before.
For the record, I'm not an auto detail kind of guy- hence why the rock chips have been accumulating for years! I'm more of a "meh, I'll wash it when it starts to look dirty" kind of guy. I'm not looking for perfection, but was pleasantly surprised by the results.
6/1/24 8:22 p.m.
I've had good luck with it matching Scion's notoriously hard to match Asphalt paint.
Slippery
Slippery UltimaDork
6/1/24 8:44 p.m.
Man, should've tried this first!
J/k, came out great! Laguna is a tough color to match otherwise.
newold_m (Forum Supporter)
newold_m (Forum Supporter) Reader
6/1/24 10:07 p.m.
Thanks for the reminder as I was procrastinating on ordering one while their Memorial Day Savings is still on (HONOR2024 for 15% until 6/4).
M2Pilot
M2Pilot Dork
6/1/24 10:23 p.m.
I've used Dr. Colorchip on several cars over the years & been very pleased.  It works better on  non-metallic paint.
adam525i
adam525i SuperDork
6/1/24 11:02 p.m.
Any close ups of some of the repairs? Just curious really, the hood looks great.
Sonic
Sonic UberDork
6/1/24 11:18 p.m.
Based totally on your recommendation I'm getting some to try on my NSX (red) and Mercedes (dark blue).
JimS
JimS Reader
6/2/24 12:10 a.m.
Going to try it on my white 911. Just white not Carrera white.
stuart in mn
stuart in mn MegaDork
6/2/24 7:20 a.m.
I used that Turtle Wax Color Magic stuff on my car years ago (it's a very dark charcoal, almost totally black) and it actually worked pretty well for what it was - from six feet away the chips weren't apparent.  I don't know how well it would have worked on other colors though.
roninsoldier83
6/2/24 10:44 a.m.
In reply to adam525i :
Absolutely! Here's a close-up at an angle (trying to take a photo straight above just resulted in too much reflection to accurately show the imperfections)- you can see some (not all) of the chip hole fixes, they're definitely darker than the OEM paint (not sure how curing + a good wax/polish would change that), but they look more like they could be specs of dirt vs rock chips:
^^^By comparison, when they were rock chips, they were bright white, which, on Laguna Blue Pearl, they stuck out like a sore thumb. These I have to look for. There are probably 10-15 holes in this area, but I can only see a handful of them (seemingly just some of the deeper ones).
This was a 1.5 inch long scratch, that was bright white in color. I can still see about a 1/2 of an inch of it, but because of it's now darker color, I actively had to search for it this morning, whereas it was always immediately visible before:
^^^I'll take that over a giant white scratch any day of the week!
As a more drastic comparison, this is the left fender that I previously used OEM Honda Laguna Blue Pearl touch up paint on. It did not turn out well to say the least and sticks out easily, whereas I have to actually look for the imperfections with the Dr. ColorChip stuff:
^^^As mentioned above, this is the reason I haven't really bothered to use the OEM Honda LBP touch-up paint again. The rock chips probably looked better lol. If you look in my original post photo from a few feet away, you can easily see where the OEM touch-up paint was used on the left fender, whereas I couldn't see any of the places I used the Dr. ColorChip stuff on. Lessons learned!
6/3/24 8:50 a.m.
Glad it worked well for you. We’ve had good experience with the product, too, and youcan read about it here on the GRM site: Can Dr. ColorChip really allow anyone to fix paint chips?
IVIwfikqHwxSan23UkizxsPJZpmmNcLkomECPvwSo0ZbFsRYzvV2sO60rv8sqpwY
