calteg
calteg Dork
10/13/16 3:36 p.m.
Just so happen to have two of these little rascals laying around after I demo'd my spa. Any practical use for them?
I was thinking large water reclamation tank and use these to push water to the irrigation system, but I know nothing about water flow rates, if that's recommended or even possible.
Huckleberry
Huckleberry MegaDork
10/13/16 3:38 p.m.
Subscribed. I also demo'd a large jet tub and have one of those.
mazdeuce
mazdeuce UltimaDork
10/13/16 3:46 p.m.
Do you have a hill? And plastic? Super slip and slide.
Toyman01
Toyman01 MegaDork
10/13/16 3:53 p.m.
It might not work for irrigation through a sprinkler. Spa pumps are high volume, fairly low pressure. Sprinklers are usually high pressure at lower volumes.
FooBag
FooBag New Reader
10/13/16 3:54 p.m.
Those pumps would not make good primary pumps for an irrigation system. They're configured for high flow but don't make enough pressure. Typical irrigation systems work best at 45-55 psi & this pump only makes roughly 30 psi with no flow & the pressure falls off quickly as the flow goes up. Additionally, the pump's optimal flow is somewhere past 120 GPM & the typical irrigation system is sized for much less than that, probably 15-25 GPM, especially if it's running on city water/well water currently.
They'd work great as transfer pumps or to pump out a basement or something like that.
codrus
codrus SuperDork
10/13/16 4:04 p.m.
Swap out the mechanical water pump in the Miata! :)
1988RedT2
1988RedT2 PowerDork
10/13/16 4:17 p.m.
I said the same thing to my wife. She laughed and said all men think their pumps are big.
calteg
calteg Dork
10/14/16 7:33 a.m.
FooBag wrote: Those pumps would not make good primary pumps for an irrigation system. They're configured for high flow but don't make enough pressure. Typical irrigation systems work best at 45-55 psi & this pump only makes roughly 30 psi with no flow & the pressure falls off quickly as the flow goes up. Additionally, the pump's optimal flow is somewhere past 120 GPM & the typical irrigation system is sized for much less than that, probably 15-25 GPM, especially if it's running on city water/well water currently. They'd work great as transfer pumps or to pump out a basement or something like that.
So you're saying I need to build my own lazy river?
Toyman01
Toyman01 MegaDork
10/14/16 7:45 a.m.
Perfect idea!
RossD
RossD UltimaDork
10/14/16 10:22 a.m.
I found their website and they have a pump curve but doesn't have the 3hp line on it, but you could extrapolate bit if you're cowboying it.
http://www.aquaflospapumps.com/aqua-flo-xp2e-3-0-hp-56fr-r0-230v-2spd-12-0-4-4-amp-05334-230/
Looks like FooBag's assessment is pretty spot on.
But thinking a little more along the irrigation lines, if you have a water tower or a nice high elevation spot compared to your plants, you can use this to periodically fill a gravity feed tank.
Brett_Murphy
Brett_Murphy PowerDork
10/14/16 11:16 a.m.
I was thinking Toyman1 could use one to recirculate water through the Saturn engine in his Jet boat if he opts for a divorced cooling system.
I think of some weird things when I'm exercising.
Trackmouse
Trackmouse Dork
10/14/16 11:57 a.m.
Those+Speed controller+go kart frame.
PMRacing
PMRacing SuperDork
10/14/16 12:10 p.m.
I thought you meant one of these
Mazdax605
Mazdax605 UltraDork
10/14/16 12:38 p.m.
Ahh, the old Toyota John Holmes water pump option! We've been over this before. Seem to remember some auto parts store shenanigans ensued.
PMRacing
PMRacing SuperDork
10/14/16 12:42 p.m.
I learned about it here.
Crackers
Crackers Reader
10/14/16 2:09 p.m.
Perfect idea!
+1
Just an fyi. Collecting rainwater is illegal in some areas.
Q5VeDB42M8qDSbYktTxoIhfsEKFnSzBxjjJSJmmzaj2xx5jWyev6bYQicrRBOM91
