11/21/23 4:02 p.m.
i already have a (borrowed) WB display, but it did not come with a sensor.  so i need a WBO2 sensor.  what is the go-to?
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) UltraDork
11/21/23 4:16 p.m.
It will very much depend on the type of display that's used. Common ones are Bosch LSU 4.2 and 4.9 and the connectors are pretty distinct. Small chance if it's fancy it uses the NGK sensor.
ralleah
ralleah PowerDork
11/21/23 7:02 p.m.
Varying different PN's for the 4.2 and 4.9 will give you different length pigtail connectors, too.
11/21/23 7:11 p.m.
Last I checked Bosch 4.9 was the best choice, it's very accurate and easy to source replacements. If you have to switch the connector, don't solder it, only crimp or twist & tape - the sensor uses the wire as an atmospheric O2 reference tube!
11/21/23 7:41 p.m.
Here's what I borrowed. It came with both cables.
Ranger50
Ranger50 MegaDork
11/21/23 9:57 p.m.
At one time the VW Bosch sensor was $30 and came with like a 3' pigtail.
RacetruckRon
RacetruckRon SuperDork
11/21/23 11:10 p.m.
AEM normally uses the 4.9 sensor same as the TermX. Per Denbob himself.
11/21/23 11:19 p.m.
In reply to RacetruckRon :
Good stuff, thanks!
RacetruckRon
11/21/23 11:51 p.m.
I think Ecoboost F150 upstream O2 and 2009ish Dodge Cummins truck had an O2 that was a wideband too if you wanted some Rockauto search terms.
infernosg
infernosg Reader
11/22/23 8:36 a.m.
Depending on the age of the setup I think the AEM can be LSU4.2 or LSU4.9. Unfortunately the connectors looks VERY similar. It's hard to tell from the picture but does your connector look like:
LSU4.2: https://www.bmotorsports.com/shop/product_info.php/products_id/732?osCsid=7nftsagofiqfk7k4i1t65jg9q6
or LSU4.9: https://www.bmotorsports.com/shop/product_info.php/products_id/2080?osCsid=7nftsagofiqfk7k4i1t65jg9q6?
I'm leaning toward LSU4.9.
11/22/23 9:53 a.m.
Looks like the 4.9 based on the proportions in the pic.
gsettle
gsettle New Reader
11/22/23 10:40 a.m.
I have this one and have been happy.
https://www.summitracing.com/parts/AVM-30-0300
Ranger50
Ranger50 MegaDork
11/22/23 11:14 a.m.
In reply to infernosg :
I think 4.2 is just an oval connector with the 4.9 being still an oval but has a "base" or "cat ears" depending how you look at it.
fatallightning
fatallightning HalfDork
11/22/23 11:16 a.m.
To piggyback off this, if that's okay, what's the go to wideband kit at moment for the money?
RacetruckRon
11/22/23 11:23 a.m.
In reply to fatallightning :
AEM X Series link
Some people really like Innovate kits for some reason, they always burn sensors out quick in my experience.
Ranger50
Ranger50 MegaDork
11/22/23 11:43 a.m.
I seem to recall that they kill sensors from excessive heater use.
RacetruckRon
11/22/23 12:00 p.m.
In reply to Ranger50 :
That's what I thought too, they were a little aggressive and crude on the heater strategy.
11/22/23 1:05 p.m.
rockauto shows all three available:
17025 -- no application listed -- $69
17212 -- Ram 2500 3500 4500 -- $60
17323 -- F150 Expedition Navigator -- $49
pretty sure i know which one i'm buying
Ranger50
Ranger50 MegaDork
11/22/23 1:08 p.m.
There wasn't a feedback on sensor temp. So more times than not, the heater was on full blast all the time.
Ranger50
Ranger50 MegaDork
11/22/23 1:09 p.m.
I know for a fact, my local podunk Oreilly's stocks them too... Because I checked with my commerical account. wink
stafford1500
stafford1500 Dork
11/22/23 1:11 p.m.
That would help explain my sensor failure...
alfadriver
alfadriver MegaDork
11/22/23 2:51 p.m.
For the more modern ones, there should be.
Andy Hollis
Andy Hollis
11/22/23 3:20 p.m.
I recently installed the AEM X kit with guage like the OP's pic and Bosch 4.9 sensor.  Didn't last very long.  Died within a couple of weeks.  I figured because of E85 use, but it sounds like heater running might be the culprit.
11/22/23 5:03 p.m.
In reply to Andy Hollis :
I read RacetruckRon's post as the Innovate kit burns up the sensor.  Interesting that you had issues with the sensor in your AEM kit.
WocYY9SaDocS4yzNbN2YpeQ2rf2IVjMMEFCMFXVAMG6GC385iszL9kk5CdMS8m3H
