problemaddict
problemaddict New Reader
7/2/08 8:57 a.m.
My GLH challenge car came to me with a mystery custom calibrated ECU. This is the MAP sensor that was attached. I'm trying to figure out if it is a 3-Bar or 2-Bar map. It looks to be a GM sensor, but the online GM part number searches are coming up empty...
Photobucket
Photobucket
The numbers are: 5227492 64469 8626A
The car is running now on a stock chrysler 2-Bar map sensor, but it seems to be running rich. It will barely run on the above map sensor and only for a few seconds. When using the GM map it throws a 'bad map' code, so i'm assuming this particular sensor is dead....
If someone could identify this thing that would be great!
thanks,
Mike
fiat22turbo
fiat22turbo SuperDork
7/2/08 3:42 p.m.
Those part numbers look to be Chrysler not GM.
Mopar CHeM, etc might help you decipher the code in your LM and verify that you have a 3-bar. My guess is that it might be a 3 or a 2.5bar map
Partsvoice.com might be a better place to look for that part number.
SupraWes
SupraWes HalfDork
7/2/08 4:11 p.m.
Looks sorta like this to me and one of the numbers match up.
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=NIE&MfrPartNumber=FE1601&PartType=414&PTSet=A
JohnnyBquick
JohnnyBquick New Reader
1/26/14 3:56 p.m.
FYI
this the the map that came with a kit sold by Chrysler to bring the map sensor from inside the car to the fender well. 2-bar I would think.
Streetwiseguy
Streetwiseguy UberDork
1/26/14 4:53 p.m.
5227492 is the chrysler number, I'd say. Phone a dealer with that number and see what they say.
novaderrik
novaderrik PowerDork
1/26/14 7:10 p.m.
beware: zombie resurrection.
PRtCuEEeaKwl3rxkiEeFJlLY6ewCxt0AXDZzcYHTV54aEFv7WR0P48LIjCLsCNrD
