kcbhiw
HalfDork
7/30/13 9:11 a.m.
I need a fitting that is similar to your typical air compressor fitting, but made for a larger hose diameter....something with the following specs:
Metal or Plastic
3/4"-1" Hose ID
Bulkhead mount female fitting (ideal, but not necessary)
Built in valve (closed when disconnected)
Will come into contact with gasoline
Does such a thing exist? I've poured over the McMaster catalog, Grainger, eBay....Maybe I'm searching the wrong criteria.
We buy from Faster. I didn't look close to see if they had what you were looking for, but check out the web page.
EvanB
PowerDork
7/30/13 9:18 a.m.
http://www.mcmaster.com/#standard-quick-disconnect-hose-couplings/=nuhr8v
You would need a separate bulkhead fitting for those. I remember seeing some last week that were bulkhead mount but I can't remember where (I believe they were Parker), I will keep looking to see what I can find.
I get a lot of this from Dixon Valve. www.dixonvalve.com
Sometimes larger air hose uses a Chicago type fitting - you would have to add a ball valve.
Search for the term "dry break". Emco invented the dry-break fitting, but it has become a universal term over the years.
Kind of pricey, ($220 each) but Uncle Summit has some -16AN quick disconnect fittings.
http://www.summitracing.com/parts/ear-240116erl/overview/
