93celicaGT2
93celicaGT2 Dork
7/18/09 7:49 p.m.
Well, i just hit 18psi on the MX6. (Yes, it's stupidly quick)
My new issue: The coupler from the last pipe to the throttle body is an autozone brand Spectre reducer, and keeps popping off.
I need a 3" (i think) down to 2.5". Where do you all like to buy your couplers, and what holds?
Thanks!
wherethefmi
wherethefmi Dork
7/18/09 7:57 p.m.
Samco, should have what you need, as far as where to get them, no help from me.
dyintorace
dyintorace Dork
7/18/09 8:42 p.m.
On our 2007 Challenge car, we used a plumbing pipe reducer from Home Depot. Cheap fix.
93celicaGT2
93celicaGT2 Dork
7/18/09 8:45 p.m.
dyintorace wrote: On our 2007 Challenge car, we used a plumbing pipe reducer from Home Depot. Cheap fix.
I've used those in the past, but from my experiences, they typically don't hold 15+psi.... I've blown holes straight through them.
Is there a certain brand or composition i should be looking for?
I may just be able to get by with a better clamp...
YaNi
YaNi Reader
7/18/09 9:08 p.m.
You just need to bead the ends of the pipe. You can either weld beads on the ends or use some old vice grips, a welder, and a grinder to make your own tool.
fiat22turbo
fiat22turbo SuperDork
7/19/09 2:23 a.m.
Can't you use a steel exhaust pipe reducer? Then you can bead it and use straight hose.
My brother used semi truck coolant hose on his GLH-S, it was seriously sturdy.
P71
P71 SuperDork
7/19/09 9:30 a.m.
If you'd look in the ads in your GRM you would see that Hose Techniques has what you need. They've been a GRM supporter for years. I ran 30+ psi in my turbo car with their IC reducers and couplers with V-Bands and never had any problems. And that was on a top-mount at that!
93gsxturbo
93gsxturbo Reader
7/19/09 12:47 p.m.
www.siliconeintakes.com
Bead the pipes, install T-Bolts. DONE.
MadScientistMatt
MadScientistMatt Dork
7/19/09 2:11 p.m.
There's a couple different sources for couplings I'm using in my Dart buildup, but the best quality ones, I picked up here:
http://www.racepartssolutions.com
They're also a GRM advertiser and I've met the guys from that company on a couple occasions.
4cylndrfury
4cylndrfury Dork
7/19/09 3:07 p.m.
+1 on beading the ends of your piping. Probably wont need new couplers if you do it.
Gimp
Gimp Dork
7/19/09 3:14 p.m.
I "beaded" my old intercooler pipes by carefully tacking coat hanger wire around the steel intercooler pipe. Often, the hanger would burn away, but it would leave a nice edge to clamp against. That, and t-bolt clamps never failed.
93celicaGT2
93celicaGT2 Dork
7/20/09 7:04 a.m.
Thanks guys.... i think i have all my info now.
I'll take care of it this week and report back. Maybe even with pictures!
I appreciatchya'all
ZJoU5cgeUXVyXfb0f3rEC4vdFmS52MvDxuFvkLUq9o8J6MvQx0dE2W5N3TmSkv4m
