I think I have asked about this before, but I figured it doesnt hurt to ask one more time to see if anyone has any other ideas. This is a 1996 subaru legacy, and a while ago the crank pully bolt came loose and ruined the crank pulley and chewed up the end of the crank. Since the car was running fine otherwise, I got a new pulley from the junkyard and put it on with locktight on the pulley and bolt. Since then it started leaking about 1 quart of oil every 100 miles from around the oil pump, and when I tried to take it apart to fix it I cant get the crank pulley off. Do I just need to go pull another junkyard longblock and scrap this one?
what colour locktight? can always burn it off.
I am unfamilier how the subaru engines run their oilpump. Could the wobbling crank pully of put something out of round?
It's red locktite, I knew when I did it it might never come off, but I didn't plan on having the car this long lol. Now it's a matter of scrapping it for $200, or spending probably another $600 (if it needs an engine, less if not) and using it for another 6 months and selling it for $1200 or so. It still seems worth fixing to me either way. Idk exactly how the oil pump works either, but it's behind the crank pulley. I don't think it leaking is related to the crank pulley problems, but it could be.
Ojala
Reader
5/17/13 5:40 p.m.
It's possible that would cause the oil leak. My concern is that those oil pumps leak profusely on most Subies so I wouldn't condemn the motor just because of it.
In an emergency once I couldn't pull the motor so I pulled the radiator and grill. I then welded a large pawn shop socket and bolt to the pulley and used a slide hammer and a healthy serving of mapp torch to free a buggered pulley.
The nut and pulley can be real bears in the best of times though so I wouldn't give up just yet.
Ojala
Reader
5/17/13 6:12 p.m.
In reply to Travis_K:
The pump slips on over the crank.
On another note: Affligem tripel is pretty darn good beer! And it's going down real well with these hotwings!
Wouldn't scrap it just yet. 5 speed IIRC, yes? Lock the flywheel and give that bolt hell, the Loctite WILL give out before the bolt. Either that or the wedge a breaker to the floor and run it over on the starter.
No, the bolt and pulley are off, the timing gear is what's stuck. I could get a whole replacement engine for ~$300, but using this one would be easier. The end of the crank isn't in real good shape though, so I won't feel too bad if it's junk.
Ojala
Reader
5/17/13 7:48 p.m.
Ohhhh, ok then. I would suggest a steel bar with two holes and two bolts to thread into the holes on the timing gear. I have seen some that weren't threaded but a tap should solve that.
And on another side note we have moved on to a "dark" wheat beer from trader joe's that is pretty good. And my kids are building a ramp for their go kart.
OH! Timing gear is loctited as well... hm. Torch and a puller?
The holes aren't threaded, I could try tapping them and using a puller that would work that way, the only way to get a puller behind it would to smash the oil pump cover out of the way, but that's going beyond the effort I'm willing to put into saving this engine. Even if I do get it apart, the crank is damaged enough the key is loose and the pulley doesn't fit tight anymore.
Ojala
Reader
5/18/13 10:26 a.m.
Well, you could just do what you are obviously wanting to do...
