Blunder
Blunder New Reader
5/13/22 3:59 p.m.
In the number 2 injector hole there is a chip. Is this gonna be a problem? It looks like it is right about where the o-ring would go.
Opti
Opti Dork
5/13/22 5:22 p.m.
As long as the Oring seals above or below it, its fine. If the o ring sits on it, just make sure it doesnt cause a vaccum leak. If you are super worried about it put a little dab of jbweld in the low spot and then sand it smooth.
Thinkkker
Thinkkker UltraDork
5/13/22 5:27 p.m.
Agreed. clean that out, swab it with Epoxy. then drill and sand smooth.  Easiest way to be sure.
Blunder
Blunder New Reader
5/13/22 9:26 p.m.
Thanks for the replies. I was worried I would have to get a different upper intake. Is there any particular jb weld that would be best?
Curtis73 (Forum Supporter)
5/14/22 11:54 a.m.
The two part gray sticks.
There are more invasive methods, like drilling and sleeving or drilling and using larger O-rings, but I don't think you need to go that far yet.
7tMibor6koieBfBhIiOvuCbIypM95a2Kn5ql2xDYsgWRAe8fGHLBmzlNwYzBa7Xd
