Taiden
Taiden SuperDork
3/8/12 3:06 p.m.
Is it safe to put one corner on a jackstand? I have to change out a cv joint and I'm just wondering if this is safe. I have plastic wheel chocks to block the opposite corner.
Don49
Don49 Reader
3/8/12 3:07 p.m.
I would lift the entire side and use 2 jackstands. It will be more stable and give you more room to work.
ransom
ransom Dork
3/8/12 3:09 p.m.
I'm going to go with 'no'.
Or at least I wouldn't. It just seems much less stable since two corners are going to extended, super-soft, and not doing much to prevent motion.
Sure I can imagine a contrived situation where it's incredibly difficult to get a second stand in there and/or where the car has nowhere to go and the point resting on the stand is a pocket so motion can't possibly cause it to fall off, but...
Unless it's an emergency and you can't get a second stand in there, I wouldn't get under a car on one stand.
Streetwiseguy
Streetwiseguy SuperDork
3/8/12 3:33 p.m.
If you are doing it to an old Renault, the doors won't close afterwards.
Apexcarver
Apexcarver SuperDork
3/8/12 3:44 p.m.
one stand allows the car to teeter back and forth. This allows the direction of forces the car makes on the stand to change. It also allows movement at the stand to car interface. This increases the odds of the car slipping off the stand. That is bad.
I would use two just for stability.
e_pie
e_pie Reader
3/8/12 3:46 p.m.
Streetwiseguy wrote: If you are doing it to an old Renault, the doors won't close afterwards.
This made me laugh a lot more than it should have, lol.
Taiden
Taiden SuperDork
3/8/12 4:37 p.m.
Alright, good to know. I ended up using two because I knew it to be safe.
mad_machine
mad_machine SuperDork
3/8/12 4:37 p.m.
was it a nervous "I did this" laugh?
I think I know what you are saying about using a single jackstand. You want to jack up one corner of the car to do a cv joint. I think if the car is not elevated much above what it would be at rest, you would be ok.. but why not jack up the whole end of the car and use two jackstands so you can get some more room by getting the car further up into the air
Taiden
Taiden SuperDork
3/8/12 5:12 p.m.
The subframe is way forward and my diff bushings are not great. I wanted to avoid tearing them and I didnt want to spend 10 minutes jacking it up by the subframe.
Johnboyjjb
Johnboyjjb Reader
3/8/12 5:59 p.m.
I use one jack stand all the time. Of course my driveway is so un-flat that I put my cars on ramps for oil changes and the pan is level and drains completely.
Tom_Spangler
Tom_Spangler Reader
3/8/12 6:01 p.m.
Or a Fox Mustang, or a third-gen F-body, or a lot of other cars. I'd avoid it just to avoid the possibility of tweaking the unibody. Probably not likely, but still.....
mad_machine
3/8/12 6:08 p.m.
years ago when I had my first fiat spider.. I worked at full service gas station. Myself and one mechanic replaced the transmission in it over the course of a few hours one night using a lift.
he left a ratchet on the floor of the car that needed.. so I climbed up to get it and he was quite shocked that I could open and close the door easily
Duke SuperDork
3/8/12 8:26 p.m.
I don't know about stability, but I left my old Poncho overnight with only the right front hoof in the air, and when I went to the garage the next morning, the windshield was cracked.
SVreX
SVreX SuperDork
3/8/12 8:38 p.m.
Old timer's rule...
Throw the spare under the car before you crawl under. If it falls, it will break your nose but it won't kill you.
Better plan... spend 10 minutes and use the jackstands properly.
irish44j
irish44j SuperDork
3/8/12 8:52 p.m.
Taiden wrote: The subframe is way forward and my diff bushings are not great. I wanted to avoid tearing them and I didnt want to spend 10 minutes jacking it up by the subframe.
IDK how low-profile your jack is, but I asssume you're talking about the e30. I put my floor jack infront of the rear wheel and push it through to the subframe and jack that direction, then put the stands in. Should allow you to at least get half-pumps in, if you're using a large floor jack/race jack.
irish44j
irish44j SuperDork
3/8/12 8:52 p.m.
also, e30 unibody isn't THAT stiff....when I have the front end up the doors definitely stick a good bit.
codrus
codrus New Reader
3/8/12 11:20 p.m.
If you were going to tweak the unibody with a single jackstand, you'd do it with the jack first.
I've done it when I was doing something quick, like changing front brake pads at the track, seemed to work OK.
novaderrik
novaderrik SuperDork
3/8/12 11:37 p.m.
i'll use a single jackstand if i'm doing something that doesn't require the car to be off the ground too far- wheel bearings, brake pads, etc..
Feedyurhed
Feedyurhed Dork
3/9/12 6:49 a.m.
I think when ever there is a question of safety it's always better to have too much than not enough.
UIj5CRYMCWLvL0ArPXE6qDOd4UsWyYvxQI2bw0cZd077fUweWae6yzdzqvQdK5F1
