markwemple
markwemple UberDork
5/17/18 2:23 p.m.
I have a few pinholes at the back of my Ducati fuel tank. Will JB Weld work??
barefootskater
barefootskater Reader
5/17/18 2:26 p.m.
For a while. I'd get something made specifically for fuel. JB may have a fuel safe variant these days.
adam525i
adam525i Reader
5/17/18 2:28 p.m.
I went through this with my Girlfriends Kia Rio, not wanting to spend $1200 on a new gas tank I used JB Weld. My research showed that you need to keep the gas away from it until it is fully set (24 hours) and then you are good, that was 2 years ago (with 2 winters) and no leaks so far. I'd imagine if it does leak it will be rust again rather then the epoxy failing.
Adam
fidelity101
fidelity101 UltraDork
5/17/18 2:39 p.m.
used it to fill in ports on the intake manifold then report it port match due to franken engine. plenty of fuel/oil exposure- its fine
APEowner
APEowner HalfDork
5/17/18 2:46 p.m.
JB weld and Permatex both make an epoxy specifically for gas tank repair.
Furious_E
Furious_E SuperDork
5/17/18 3:24 p.m.
In reply to barefootskater :
This has been my experience as well. Used it to fill pin holes in a gas tank on an old dirt bike project, held up fine for a few months, then started seeping.
44Dwarf
44Dwarf UberDork
5/17/18 4:46 p.m.
Gorilla tape to hold it while you seal with Caswell platings gas tank sealer. once sealer sets up peel off the tape.
wearymicrobe
wearymicrobe UberDork
5/17/18 4:46 p.m.
They make one specifically for ETOH fuels. The old stuff DOES NOT WORK it will just turn to tar and ruin everything.
SyntheticBlinkerFluid
5/17/18 7:58 p.m.
What type of metal is it? Steel Stik may work.
M2Pilot
M2Pilot Dork
5/17/18 8:23 p.m.
POR-15 sells a fuel tank repair kit. It was used to seal tank on my 2002 over 15 years ago.  No problems. I don't know if they make the product in size appropriate for motorsickle tanks
markwemple
markwemple UberDork
5/17/18 8:43 p.m.
In reply to SyntheticBlinkerFluid :
Steel
dean1484
dean1484 MegaDork
5/18/18 7:15 a.m.
Take it off and clean it and solder it. I have done it many times over the years. Or take it to a old school radiator shop and they can do it.
8UkqTwOC0tMwCGQlI9To4mvmkKNDM2r5C4FPOVFHgsqMoQnQ10jKM9zfMJiUpKcT
