Taiden
Taiden HalfDork
6/11/11 2:06 p.m.
Alright, sooooo yeah. It's raining here in beautiful Maine, and I decided whilst at a stand still to launch my 318i. Rev to about 4.5k and ceremoniously dump the clutch (but not in a side-stepping fashion, slightly more gentle).
The car bogged down and proceeded to run like ass.
At first I was sure that it was my AFM stuck wide open, as was previously the issue. At first it was running, but would hardly operate under load. After checking a few things, the car won't even run now. It just sputters randomly.
The things that I checked:
  1. vacuum lines
  2. AFM
  3. all visible EFI related plugs
  4. checked for loose plug wires
  5. checked for damaged cap/rotor
  6. cleared the engine to check for flooding
The car is currently on the side of the road somewhere and I will be returning to it to try some other things. Any ideas would be appreciated.
Giant Purple Snorklewacker
6/11/11 2:10 p.m.
Take the distributor cap off and see if its all in-tact in there (assuming E30 318 since you said AFM and not MAF...).
mad_machine
mad_machine SuperDork
6/11/11 2:10 p.m.
maybe you got water somewhere it shouldn't have been? Generally a launch only breaks mechanical things that make the car go.. not parts that make the engine run
Taiden
Taiden HalfDork
6/11/11 2:23 p.m.
Snorkle: I did check, but I have a spare rotor here that I'll throw in for the hell of it.
Mad_Machine: I know... it's totally stumped me. I've never heard of this happening before. I may just have to go through the motions.
mad_machine
6/11/11 2:26 p.m.
318i uses a timing belt or a chain?
Might need to check your timing.. both at the distributer and the cam
Taiden
Taiden HalfDork
6/11/11 2:29 p.m.
Timing chain
ww
ww SuperDork
6/11/11 3:31 p.m.
Is that an answer or a question?
I assume your timing chain slipped?
Ranger50
Ranger50 HalfDork
6/11/11 3:50 p.m.
It's broke. Sounds timing related as it seems to want to run, but doesn't.
Taiden
Taiden HalfDork
6/11/11 4:28 p.m.
Sorry. I found it. Pretty funny, had excellent spark at all four plugs, swapped in a spare AFM, car still didn't run, but it was backfiring sporadically.
Pulled the cap off, and turned the rotor. Uhmmm. I don't think rotors are supposed to turn 360* when the crank isn't moving.
$7.60 later at a NAPA that was a 1/4 mile away and I was on the road again.
The culprit:
Ranger50
Ranger50 HalfDork
6/11/11 5:45 p.m.
{sarcasm} Awesome Made in USA part.{/sarcasm}
Taiden
Taiden HalfDork
6/11/11 7:53 p.m.
We had a good laugh about that.
MitchellC
MitchellC Dork
6/11/11 8:46 p.m.
So you ceremoniously dumped the clutch when leaving the NAPA parking lot, right?
Taiden
Taiden HalfDork
6/11/11 8:51 p.m.
In reply to MitchellC:
Sure did, but in a more timid manner.
6/11/11 9:05 p.m.
What do I win :)
mad_machine
6/12/11 6:47 p.m.
wooo.. love a cheap fix!
Taiden
Taiden HalfDork
6/12/11 6:52 p.m.
Snorklewacker, you win the pride of winning!
Unless you want the old rotor. It was going to go on my wall of shame, but you can have it if you like.
a0gAJC7JMEMNZASJEu2aKExcXTljPbxq5pY6vP4PXzonRBOSmpnHR35UoLOyGutF
