Carrera4
Carrera4 Reader
10/31/10 8:19 a.m.
Depends. How much to pick it up?
Mikey52_1
Mikey52_1 HalfDork
10/31/10 9:23 a.m.
Carrera4 wrote: Depends. How much to pick it up?
NO, I'm almost certain that's not what he meant...
docwyte
docwyte Reader
11/1/10 8:59 a.m.
Oil pan gaskets, clutches, front oil seals and belts, etc. The belts need to be changed every 30k miles. If it isn't documented, DO THEM. The clutch is a serious PITA to replace, try to buy a car with a recently replaced one. Same thing with the oil pan gasket.
These are fun cars that if mildly neglected will cost you a TON of money to set back right.
snipes
snipes Reader
11/1/10 11:05 a.m.
stumpmj
stumpmj Dork
11/1/10 11:13 a.m.
And they like to eat the #2 rod bearing when run on the track. Additions like a baffeled oil pan, crank scraper, etc help but don't seem to completely cure the problem. When the rod bearings spin, the cylinder liners scuff and then you need a new block since the bores are Nikasil (sp?) plated.
16vCorey
16vCorey SuperDork
11/1/10 12:55 p.m.
snipes wrote: don't you need an very expensive tool to do that timing belt ever 30,000 mile? $450 on ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=150510794879&crlp=1_263602_304642&ff4=263602_304642&viewitem=&guid=e925d13012b0a06456375027ffec9ada&rvr_id=161387764987&ua=WXF%3F&itemid=150510794879
I've done plenty of them without it and never had a problem.
dean1484
dean1484 Dork
11/1/10 3:17 p.m.
This may help:
http://www.clarks-garage.com/purchase.htm
Add an Accusump (as I did) and the whole #2 rod bearing thing goes away. about a $200-300 fix.
Old photo from my car. I have updated things (zip ties don't pass tech)
Great track car. By today's standards a bit heavy but HPDE and general track fun it is a great car.
Wait.. . . ya they suck!!!! Don't get it!!!! By not purchasing you are keeping the prices of these cars deflated so I can own them all!!!!
cSkGcsbyf8ZEozewAetdQZjm6M1CMfYypv5BF3HF1GK2O1VMEXJPGNQa9j6xEAsE
