f6sk
f6sk Reader
5/5/15 1:08 p.m.
Are we there yet? Can I now plug my phone into my car and get the codes/ check the info? What is the best ap/hardware for this?
Jerry
Jerry SuperDork
5/5/15 2:21 p.m.
This is where everyone says Torque, and a BlueTooth adapter. (Only one I know of.)
foxtrapper
foxtrapper UltimaDork
5/5/15 2:53 p.m.
Yep, that's what I use. Works very well.
f6sk
f6sk Reader
5/5/15 2:59 p.m.
this one? https://www.youtube.com/watch?v=vQSsUPrGLHs
EvanR
EvanR Dork
5/5/15 5:17 p.m.
I got a $50 refurb 7" tablet with Bluetooth. If you have a way to mount it, it's a lot easier to read than a phone screen, and then your phone isn't tied up.
irish44j
irish44j PowerDork
5/5/15 5:52 p.m.
I have a $5 ebay bluetooth OBD plug-in and link it up with Torque Pro app on my phone. Regular Torque is free, but Pro is like $5 and you get programmable things like torque converter temp and stuff like that. I really only use the setup when I'm towing, so I can keep tabs on the TC and transmission temps.
Just like Jerry said
solfly
solfly HalfDork
5/5/15 7:29 p.m.
http://www.amazon.com/Newest-Bluetooth-Diagnostic-Scanner-Adapter/dp/B009F4JHHO/ref=pd_sim__3?ie=UTF8&refRID=1NHH8EP9MBSCQCRS5BS6
stanger_missle
stanger_missle Dork
5/5/15 7:30 p.m.
I bought this Bluetooth ELM327 scanner: http://www.amazon.com/gp/product/B0051CAE1C/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
And this OBD2 extension cable: http://www.amazon.com/gp/product/B007PAHHWM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I did use Torque Pro but I couldn't use a lot of the functions (stupid Chrysler). I also was not impressed with the GUI. I ended up using DashCommand. It does 95% of what Torque does but with a much cleaner interface. DashCommand
I tucked the cable and Blutetooth scanner up into the dash of my Wrangler. With the 90° OBD2 plug, it doesn't hang down into the footwell. I have been using this setup since July of 2014 and have had zero issues. I mainly use it to monitor/datalog intake temps on my Jeep with a snorkle and verify speedometer accuracy.
ssswitch
ssswitch Reader
5/5/15 7:45 p.m.
Note that the Bluetooth OBD2 scanners don't necessarily work on the iPhone. I found this one out the hard way.
I ended up buying a WiFi one (Panlong "PL-WIFI" ELM327) and using OBDCarDoctor to scan codes.
f6sk
f6sk Reader
5/6/15 7:39 a.m.
You guys sold me on this. I just bought the ap and an I-Phone specific blue tooth plug off amazon. Total investment $22
Mazdax605
Mazdax605 SuperDork
5/12/15 7:35 p.m.
So I ordered a Bluetooth scanner dongle thing on Amazon and downloaded torque for my android phone. Once I figured out how to pair it I was able to get the code that is causing my check engine light. It said o2 sensor low voltage bank 2 sensor 2 I think. What does this mean?
Chris
Mazdax605
Mazdax605 SuperDork
5/13/15 5:36 a.m.
Sorry I just re-read the trouble code and it is bank 2 sensor 2. Which of the oxygen sensors is that?
flatlander937
flatlander937 New Reader
5/13/15 8:47 a.m.
Bank 2 O2 after the cat. Find out which cyl is #1.. That side is bank 1. So other side.
If you have a weird setup like a Jeep I6 or BMW bank 1 is first 3 cyl, bank 2 is second 3 cyl.
What is the specific code? Lean? Rich? Stuck? Monitor B2S2 voltage while driving. Should read lean(over .600v) pretty constantly, maybe exception under throttle, with little to no switching. If it switches from .1-.9v like B2S1 should, that points to a bad cat.
Edit: low voltage got it. Monitor it, likely internally shorted or open circuit.
1PyXSNxicr9q8rnJRdOvDsSym7SuBmhB3cdlL1VRcZk7Z9O4tY4aI6zGjGCDyJrY
