Are they universal? I need a 5/16" hose barb on each end. And it's gotta be EFI. I found a dodge caravan v6 fuel filter fits this exactly, I'm just worried about flow. Are they pretty universal as far as restrictions go?
Yes.
*Unless you drive a car that has a built in fuel pressure regulator in it. Easily identifiable because it will have 3 or 4 lines going in to it.
Once the fittings are the right size I wouldn't worry about restriction, that would only come into play if you're doing something custom with seriously undersized fuel lines. Just don't put a filter meant for a carbed vehicle's low/slight negative pressure system on an EFI'd car!
I use to have fuel starvation issues with my 240sx when I auto-xed with less than 1/3 tank of fuel. I upgraded my fuel filter to the larger 300ZX TT filter and it worked as a surge tank. It was larger in size and less restriction in the inlet/outlets. Now I can run it until the fuel light comes on without starvation.
GameboyRMH wrote: Once the fittings are the right size I wouldn't worry about restriction, that would only come into play if you're doing something custom with seriously undersized fuel lines. Just don't put a filter meant for a carbed vehicle's low/slight negative pressure system on an EFI'd car!
I can only Imagine the carnage.
