N Sperlo
N Sperlo MegaDork
4/23/16 12:54 a.m.
Not the housings, but the bulbs.
The headlights on the P71 are dull and improperly aimed. I found some low priced housings and are crystal clear and they just came in. Next step is the actual bulbs.
The current bulbs are E36 M3ty and I can barely see in wet weather. I have midrange silverstars in the F150 and love how well they work even in foggy, water-logged housings. They work well in all weather.
I'm looking at OEM options and HID conversions and I'm not convinced of one or the other. We're talking a stockish color as well. No fancy blue or yellers.
Anyone have experience or suggestions in this area?
Stefan (Not Bruce)
Stefan (Not Bruce) MegaDork
4/23/16 1:15 a.m.
A good set of relays, silverstars and a proper aiming.
Done.
N Sperlo
N Sperlo MegaDork
4/23/16 1:18 a.m.
In reply to Stefan (Not Bruce):
I did not even consider relays as an option. Great idea.
WildScotsRacing
WildScotsRacing HalfDork
4/23/16 6:54 a.m.
Concur on the Silverstars. Don't bother with the Silverstar Ultras, however.
hhaase
hhaase New Reader
4/23/16 6:57 a.m.
Yeah, always relays if you can. A lot of cars out there will start melting headlight switches if you increase bulb wattage.
XLR99
XLR99 Dork
4/23/16 7:37 a.m.
On the recommendation of a couple people on here, I've been using Sylvania Xtravision bulbs in the fleet.
TGMF
TGMF Reader
4/23/16 7:50 a.m.
I put Phillips xtreme vision in my wife's ford escape for the same reasons. Phillips claims 100% brighter than standard bulbs. Don't know about that, but they are definetly a big improvement in the mid range as well as sides of the road illumination. They are the same wattage as stock, so a drop in install.
chiodos
chiodos Dork
4/23/16 7:57 a.m.
DO NOT even consider hid's in a reflector housing. Unless you have projectors you will have worse visibility than normal halogens not to mention blinding every person you pass with scattered light. I wish the brodozers in my area understood this...
M2Pilot
M2Pilot HalfDork
4/23/16 8:55 a.m.
chiodos wrote: DO NOT even consider hid's in a reflector housing. Unless you have projectors you will have worse visibility than normal halogens not to mention blinding every person you pass with scattered light. I wish the brodozers in my area understood this...
I suspect that the brodozers in you area (and everywhere else) already understand this. It just enhances their asshattery.
TIGMOTORSPORTS
TIGMOTORSPORTS HalfDork
4/23/16 9:13 a.m.
Silverstar Ultra has my vote. Pack of 2 and use the Advance Auto Parts online order discount/pickup to save $
XLR99
XLR99 Dork
4/23/16 9:21 a.m.
Based on what I see around here, brodozer pilot comprehension of, well, anything seems pretty minimal. Apart from the 'Hey look at me. I'm cool!' thing.
chiodos
chiodos Dork
4/23/16 9:30 a.m.
In reply to M2Pilot:
It still blows my mind that although illegal, no cops do anything about it every.
N Sperlo
N Sperlo MegaDork
4/23/16 11:29 a.m.
chiodos wrote: In reply to M2Pilot: It still blows my mind that although illegal, no cops do anything about it every.
It would involve inspections, paperwork, and generally be a pain in the assignment.
Anyway, this thread solves my problem.
1kris06
1kris06 Reader
4/23/16 12:49 p.m.
It would involve inspections, paperwork, and generally be a pain in the assignment. Anyway, this thread solves my problem.
It's actually a stupidly easy test, but that's neither here nor there. Cops don't give two E36 M3s about equipment violations.
mad_machine
mad_machine MegaDork
4/23/16 1:21 p.m.
but they do give reasons to pull you and run your license
BrokenYugo
BrokenYugo UltimaDork
4/23/16 3:45 p.m.
Dunno about the P71 in particular, but it's often less of a housing/bulb issue and more of a marginal when new, bad when old wiring problem. Check voltage at the bulb with the lights on.
GTwannaB
GTwannaB HalfDork
4/23/16 4:28 p.m.
On this subject, what about LED conversions? It looks like they come with some sort of heat sinks, do these things tend to melt?
dj06482
dj06482 SuperDork
4/23/16 8:57 p.m.
I run Sylvania Xtravisions - cheaper than the Silverstars, and similar output (but without the "whiter" light).
RealMiniParker
RealMiniParker UberDork
4/24/16 12:48 a.m.
WildScotsRacing wrote: Concur on the Silverstars. Don't bother with the Silverstar Ultras, however.
Agreed. After having a couple Ultra bulbs burn out in a ridiculously short time, I gave the regular Silverstars a try, and was pleased with the very comparable brightness and longer life, at a lower price.
SyntheticBlinkerFluid
4/24/16 10:43 a.m.
Do not go with HIDs unless you have a projector lens type housing. The reason conversions blind people is because they are put in a stock reflector housing. If you look at most cars that have HID lights stock, the bulb is behind a projector lens. You need that lens to direct the lighting to where it needs to be.
hud41dIf0A9nWefFH93FS6pr644nPle4zlcIBJfVNfFXwWw8x77gqxED6tz0A18X
