Teh E36 M3
Teh E36 M3 Dork
11/25/12 4:39 p.m.
curtis73 wrote:
novaderrik wrote: why can't you put some 30" tall load range E tires on that Bonneville? it probably came with 28" tall tires stock and the wheelwells were absolutely massive back then.
The wheel wells are pretty big, but unless I jack up the car I won't have any suspension travel. It came with 26.8" tires stock. I have 225/65-16s on it now just because I had them sitting around. I'm hoping to at least fit 235/70s but that will be a stretch.
a few 1/8" steel boxing plates added to the frame and you've got yourself a car chassis that's every bit as good as any 3/4 ton truck chassis.
Well, i wouldn't say as good as, but I do plan to box the frame and add a K-frame or X-frame to it. This is the first build where I'm actually not concerned about adding weight.
hell, an entire floater rear end out of a 3/4 ton truck might just slide under there with a little bit of fabrication.
It does, and I did. 10.5" full floater with a posi and 3.21 gears. Photobucket Photobucket Photobucket Photobucket
That is so bad. I love it. Would love to see it in action. Wasn't there a lincoln convertible with powerstroke engine and hydraulics or something floating around? Not so much a tow vehicle, but badass anyway. I'm all for the idea of strengthening the frame of something like that and towing the airstream around. Cool and cool.
qEjrUtdBINmLzMZ4RV9Ymsr0YDqm3IjgsHqBkbUoY3vHxJvgcyhE5Rv9KTrAiPhz
