Floating Doc
Floating Doc Reader
2/14/18 11:26 a.m.
The window tint on my newly acquired miata is really dark.  Before I decide to have it removed, I thought I would try adding better illumination from my reverse lights. Anyone have an opinion on switching from incandescent to LED replacement bulbs?
RossD
RossD MegaDork
2/14/18 11:29 a.m.
Put the top down?
Sorry, I'm no help. wink
2/14/18 11:35 a.m.
I'm also interested in how much brighter these are.
One trick I've done to get more brightness out of the existing bulb is to use aluminum tape to add a reflector in the taillight housing if there isn't one already.
bigdaddylee82
bigdaddylee82 UltraDork
2/14/18 11:38 a.m.
While not exactly what you're asking for...
First new top I put on my Jeep Wrangler, I splurged and got the tinted vinyl rear and side windows.  I similarly couldn't see very well when backing up at night.
I mounted something very similar to these, Blazer Driving Light Kit, on my rear bumper, and wired them to a toggle switch on my dash.  I could see great when backing up, and with them angled up just slightly, they worked great to remedy tailgaters too.  wink
chaparral
chaparral Dork
2/14/18 11:41 a.m.
One ticket for a burned-out bulb is more expensive than switching every car you'll ever own to LED turn signal, taillight, and reverse light bulbs.
2/14/18 11:46 a.m.
My Miata has LEDs for every exterior light. I haven't noticed that the reverse lights are particularly brighter but they are a different color temperature.
2/14/18 11:48 a.m.
I dunno, I see those bulbs (DOT LED 1156 & 1157) going for $10~$20 a piece...how much are the tickets by you?
chaparral
chaparral Dork
2/14/18 12:46 p.m.
$50-$150 for the ticket, and then $250-$500 per year for 3-5 years in insurance surcharges.
RevRico
RevRico UltraDork
2/14/18 12:47 p.m.
In reply to chaparral :
Fix it tickets count against your insurance? What state is that?
Kylini
Kylini Dork
2/14/18 12:57 p.m.
I know on my 1999 Miata, the Sylvania LEDs at Advanced Auto will either illuminate for idle-on, but not brakes depressed; or instead for brakes depressed, but not idle-on depending on if you install em 180 degrees off or not. Immediately returned for an incandescent that worked.
Make sure to test your lights before re-attaching the lamp to the car.
2/14/18 12:57 p.m.
OK I just ordered 4 of these, the cheapest I've seen yet:
https://www.amazon.ca/dp/B01NCOHKCZ/
I'll see how they work around the end of this month. I want to reduce the load on my Samurai's taillight circuit so that I can install a high-mounted brake light and LED cube reverse fog without running more wires from the front of the vehicle (instead, just tapping into the existing brake light wiring). Also I don't want my Corolla to burn its battery down while the brake pedal is clamped during alignments (it has 4 1157s plus an LED "jumbo peanut" in the spoiler brake light). If they're brighter I'll consider that a bonus, and will look into ordering white ones for my Samurai's reverse lights.
BoxheadCougarTim
BoxheadCougarTim MegaDork
2/14/18 1:04 p.m.
IME the standard replacement bulbs usually aren't much brighter, if any, than the stock incandescents. The major advantage is in their longevity.
chaparral
chaparral Dork
2/14/18 1:06 p.m.
In reply to RevRico :
In MI/TX/MA they're fix-it tickets only at the officer's and judge's discretion. If they want to they can throw the book at you and these are all points-bearing offenses.
mad_machine
mad_machine MegaDork
2/14/18 2:01 p.m.
NJ a fix-it ticket is a non-points bearing ticket. They would also never ticket for non-op reverse lights. Heck, I am not sure they ticket for non-op brake likes by how many cars I see running around with only the 3rd brake light working.
I put those Sylvania LEDs in my Rover. Rear Fog, reversing, and the brake/running lights. Much brighter than stock and the differing colour temp makes them more noticible.
CDvk554e45dGSFDYEWmqFLHEsx1zegJLOYRCFDBAEzRWOE83vCEJkMJJyG2A2HrP
