LainfordExpress
LainfordExpress New Reader
12/29/10 10:55 a.m.
1980 1st Gen. RX-7... what do I need to know.
I've been reading about checking the coolant for oil and the hatch channels for rust. Rust doesn't look like it'll be an issue though.
Anything else I should know?
Mazdax605
Mazdax605 HalfDork
12/29/10 11:28 a.m.
Suspension mounts in the rear wheel wells tend to rust out. Oil leaks on the engine between the housings. Smoke on start up? 79-80 are the best in my opinion by the way.
Chris
Javelin
Javelin SuperDork
12/29/10 11:31 a.m.
Make sure the engine is cold when you get there and watch for the amount of smoke on start-up and the length of time it takes to warm up. Look over the coolant system carefully. Check for rust in: rockers, rear wheelwells, under the battery, in the cowl, under the storage bins, and the rear suspension mounts. Look under the car to see if all the heat shielding is still in place and how fubared the frame rails are (they are very weak and if used as a jacking point usually buckle).
Enjoy! I still miss mine greatly.
pilotbraden
pilotbraden Reader
12/29/10 1:39 p.m.
Mine, a GSL SE, would smoke heavily on cold days when I had too much oil premixed. It still starts easily and pulls hard, with 245,000 miles on it. I recommend a touch of 2 stroke oil at every fill up.
aussiesmg
aussiesmg SuperDork
12/29/10 2:19 p.m.
www.rx7club.com
it's all covered there
corytate
corytate New Reader
12/29/10 3:18 p.m.
Mazdax605 wrote: 79-80 are the best in my opinion by the way.
I'll second that
first gens are the only ones with solid rears, IIRC solid rear ftw!
lol.
pilotbraden
pilotbraden Reader
12/29/10 3:26 p.m.
I want to put the engine from an RX-8 in a clean (rustless) early RX-7
Moparman
Moparman Reader
12/29/10 3:59 p.m.
I have an 85 FB which is clean and was painted a few years ago and kept in may garage since that I could be tempted top part with.
Mazdax605
Mazdax605 HalfDork
12/29/10 4:06 p.m.
I'll second that first gens are the only ones with solid rears, IIRC solid rear ftw! lol.
The 79-80's are also the only ones with the cool looking steel bumpers rather than the more socially accepted,but lame looking (In my opinion) urethane bumpers.
LainfordExpress
12/29/10 9:09 p.m.
Can anyone point me in the right direction for aftermarket wheels on these? The bolt pattern is goofy... 4x100 maybe? 4x110? I dunno Tire rack is non helpful and I'm having difficulty figuring out how much offset I need.
Mazdax605
Mazdax605 HalfDork
12/29/10 9:58 p.m.
4X110mm pcd,and you are right they are an odd pattern. There are choices out there,but not nearly as good as if it were a 84-85 GSL-SE model which uses the much more common 4x114.3 pcd. There are some old school choices out there,but they are rare,and expensive,but very cool. I have a set of Weds Auto Bahn's in 15"x7",and I love them. You can also try to find a set of 83 Limited Edition RX-7 wheels that are a BBS basket weave pattern,and are a more friendly 14" size,and the proper offset. I have another set,but they are in need of refurbishing. I could be talked into selling them I suppose.
LainfordExpress
12/30/10 6:00 a.m.
Yeah, I had found some weird brand that had fairly lightweight alloys with smaller sizes, 14", 15" x 6" or 7". It was something like 686 or 696 I think, but can't find them now. Oh well, maybe I bookmarked them at home.
I think I'd rather just pick up a second set of stock wheels to mount up for autocross. I'm planning on keeping it pretty stock anyway, and it'll be even harder to find something aftermarket in a stock size.
Toyman01
Toyman01 SuperDork
12/30/10 6:37 a.m.
Konig and Rota still make 4X110 wheels for the FB. E-bay lists several of them. Unfortunately that is also a common ATV bolt pattern so you have to wade through the ATV wheels to find them.
Toyman01
Toyman01 SuperDork
12/30/10 6:39 a.m.
Here's a link to a set.
As far as offset, +20 seems to be what fits.
Javelin
Javelin SuperDork
12/30/10 8:26 a.m.
Rota RB's are your only aftermarket choice in current production for the 4x110 RX-7 wheels. A lot of guys import over old school wheels from Japan or Australia.
I have a set of 14" Hayashi Street II's waiting for the right RX-7 owner though...
Moparman
Moparman Reader
12/30/10 8:28 a.m.
What about Konig Rewinds?
SyntheticBlinkerFluid
SyntheticBlinkerFluid Reader
12/30/10 12:29 p.m.
I have a '80 and it's the best IMO. My oil seals went between the rotor chamber and side housing. If there is any excessive smoke at startup, don't stress, it's rather common.
Has this car been sitting, or is it a running driver?
grimmelshanks
grimmelshanks HalfDork
12/30/10 1:26 p.m.
doesnt diamond make steel wheels that fit 1st gens?
LainfordExpress
12/30/10 8:29 p.m.
Guy called tonight, call is sold. Fooey.
Moparman
Moparman Reader
12/30/10 8:47 p.m.
I have an 85 I would consider selling.
ljk1UtMRobT2GpudPNaNcQ9GLSfV4CNjU80oUCkkSRkDPfHLMFA3T2lgsMEk7KuZ
