In an effort to not mess around with a universal sender, i'm looking at something that runs around 7ohms full, 32.5ohms at half, and 95ohms empty.
Is this non-linear curve going to screw me?
Swank Force One wrote: Is this non-linear curve going to screw me?
From my general electronics knowledge, hell yes.
You might be better off using a microcontroller to alter the signal from a universal sender.
If i use a universal sender, i won't need to alter the signal.
I was trying to use the OEM sender, but this seems like a pain in the ass.
Depending on the shape of the tank in question, this non linear data you pulled may well be linear when actually in the tank. Run a universal and just deal with the non linear movement, just like 90% of cars with mechanical gas gauges did.
It really comes down to how much you care. If the tank is an irregular shape and it has to be accurate, a microprocessor setup is needed to linearize the output. If you just want a rough reading, any float type is fine as long as it reads zero and 100% okay. I used the capacitive type with adjustable empty and full settings, but not cheap.
