crazyb
crazyb New Reader
5/1/11 2:04 p.m.
So I am looking to get some 15x10 for my E30. So what would be the best place to look for wheels. My budget is about 250 a wheel.
Would love to run some 275x15 hoosiers on the car.
motomoron
motomoron HalfDork
5/1/11 3:18 p.m.
Keizer and Real are big in the dirt oval community. Real is less expensive than Keizer - I had both quote custom wheels for my Radical when I realized most of the unimaginably expensive Kodiak wheels it came with were bent. Ultimately I had enough straight wheel halves and spares to assemble a good set. That's a nice thing about 3-piece wheels.
Real Racing Wheels
Keizer Wheels
Diamond is ground zero for steel wheels in funny sizes. I've seen a lot of these in the nearly-square sizes at the autocross - like 13x10s for the C-mod guys.
Diamond Wheels
crazyb
crazyb New Reader
5/1/11 3:20 p.m.
Yeah I looked at diamond wheels but the things can double as boat anchors.
Duke SuperDork
5/1/11 3:38 p.m.
If your budget is $250 per corner in 15x10 first off I would call up 949Racing and see what Emilio can do for you. 6ULs are a little over 13 lbs each in that size. Not sure what the backspace and offset is for the E30 but he is huge in the Miata world. He's even looking at offering 15x11s.
mw
mw HalfDork
5/1/11 6:02 p.m.
If you could be happy with 15x9's the tirerack makes one that is roughly 15lbs and $109 each. It will hold the 275 Hoosiers nicely. If you're trying to find them on their site, enter your vehicle as a 99 mazda miata str street tire class
DirtE30
DirtE30 New Reader
5/1/11 6:07 p.m.
we were able to fit 15x10 bassett wide 5 wheels on our E30 but it took us about a thousand hours of body work to get them to look right.
crazyb
crazyb New Reader
5/1/11 6:11 p.m.
As far as body work, I was thinking of cutting the fenders out and running 2002 style rivet on flares.
DirtE30
DirtE30 New Reader
5/1/11 6:14 p.m.
crazyb wrote: As far as body work, I was thinking of cutting the fenders out and running 2002 style rivet on flares.
yeah we did that option first.
crazyb
crazyb New Reader
5/1/11 6:43 p.m.
Did it not work well? or did you not like the look?
fast_eddie_72
fast_eddie_72 Dork
5/1/11 7:22 p.m.
Some autocross guys I trust said Spinwerks 82s are the way to go. That's what I'm planning to get - right at your budget too.
pimpm3
pimpm3 Reader
5/2/11 1:40 a.m.
A local guy runs 295 on his e30, I am not sure what size rims he is using but I know everything was done on a tight budget. I will see if I can figure out what he is running. The whole car was done inexpensivly and he is very fast and consistent.
pimpm3
pimpm3 Reader
5/2/11 1:56 a.m.
I figured it out he runs 17x9 Falken Hanabi Wheels. He is actually selling them here for 800 with tires....
http://www.buccaneerregion.org/classifieds.html
motomoron
motomoron HalfDork
5/3/11 8:44 a.m.
The Real Racing wheels are under 10# and under $250 probably. 13x7s and 13x9s for the radical were like $175 and $200.
conesare2seconds
conesare2seconds Reader
5/3/11 12:14 p.m.
Hanabis are quite light.
crazyb
crazyb New Reader
5/3/11 12:28 p.m.
Hmm the Hanabi is an interesting option. Lots of tire options in 17. Wonder how big of spacer I would need to run this and if I would need adapter due yo different center bore.
mad_machine
mad_machine SuperDork
5/3/11 12:53 p.m.
are you still running the 4 lug hubs? If you get the rears from a 318ti or even better, A z3m (wider and stronger) you can use e36 front struts and hubs to go 5 bolt
B5gWiWfwDz3yf6TYqoEDT32fAJ6n0hTHnqdOSH6bpJnRJOWCRdtRUTJ4bvP2UIo0
