D2W
D2W HalfDork
10/20/17 9:56 a.m.
Anybody have any experience with this. There is a 996 on Pelican, I think a 2000. It is a roller with a blown motor. Good looking car but what is the real cost of putting an LS motor in.
RossD
RossD MegaDork
10/20/17 10:01 a.m.
We've discussed this before... but can't remember what the opinion was.
http://www.renegadehybrids.com/
or
https://www.kennedyeng.com/engine-adapters
Tom_Spangler
Tom_Spangler UberDork
10/20/17 10:24 a.m.
Hoovies Garage on Youtube recently did an LS swap in a 996.  It's a big, expensive job.....
D2W
D2W HalfDork
10/20/17 10:48 a.m.
That's kind of what I expected. If I wanted a stripped down lightweight hoonigan car it would probably be a fun project.
10/20/17 11:05 a.m.
On one of my recent track outings, the only car I could play with was an 80's 911 with an LS7 in the tail. We had a lot of fun - he could come off 2nd gear hairpins harder, I'd pull him down the straight. Unfortunately, he had a bit of work to do on cooling.
But I dug it a lot.
Engine swaps are always more difficult and more expensive than you expect if you want to do them properly.
NOHOME UltimaDork
10/20/17 11:19 a.m.
Stefan
Stefan MegaDork
10/20/17 11:21 a.m.
I'd just rebuild the flat 6 for it, put it back together to have some fun and then sell it on.
If you really want to engine swap it, make it mid-engined and Audi V8 powered since they came with a transaxle.
Ian F
Ian F MegaDork
10/20/17 11:22 a.m.
In reply to Keith Tanner :
In theory, a 996 "should" be easier to swap than an 80's 911.  At least the 996 uses a water cooled engine as well.
D2W
D2W HalfDork
10/20/17 12:03 p.m.
He cracked the engine case in a track incident that likely completely destroyed the motor. Definitely not worth rebuilding to stock unless you already have a spare motor.
Better options out there if I wanted mid engine.
D2W
D2W HalfDork
10/20/17 12:05 p.m.
Other than electronics, maybe. Air cooled 911's are pretty simple, and there are quite a few solutions to water cooling them.
Jaynen
Jaynen SuperDork
10/20/17 12:08 p.m.
People complain about the weight on LS swaps in miata what is putting an LS on the back end of a 911 going to do?
D2W
D2W HalfDork
10/20/17 12:10 p.m.
Porsche motors are surprisingly large and heavy. Fully loaded on a scale they are very close.
Stefan
Stefan MegaDork
10/20/17 12:15 p.m.
Hit car-part.com for a spare motor, combine them, have fun and sell for profit.
D2W
D2W HalfDork
10/20/17 12:45 p.m.
That probably is the best plan for this particular car. But its always fun to dream about crazy things.
ahutson03
ahutson03 Reader
10/20/17 1:24 p.m.
Yeah I'm with everybody else...  at least if you were installing a good running motor it would be easy to do the ims bearing before you drop the body on top of it... although.... I do find it interesting that an ls1 weighs the same as the flat 6.....
stuart in mn
stuart in mn UltimaDork
10/20/17 1:42 p.m.
I just started watching his videos recently - it's an interesting take on buying really cheap exotic cars that were really expensive when new.
markwemple
markwemple UltraDork
10/20/17 1:50 p.m.
Most Porsche people believe that the best part of a 911 is the ENGINE. Just saying......
10/20/17 1:55 p.m.
Not people who have ever built or driven one complain about the weight. That's usually a knee-jerk reaction based on what my daddy tol' me.
yupididit
yupididit Dork
10/20/17 2:05 p.m.
I knew a guy in Chicago who built one. Then sold it to a navy pilot who wrecked it. He liked it a lot but not enough, he's a guy who has owned Vipers and currently has a Lambo.
D2W
D2W HalfDork
10/20/17 2:06 p.m.
I wouldn't deny that a 911 motor is special. I would argue that the price of buy in on the air cooled ones is steep, for frankly not a lot of power. I have seen a used crank from a 3.0 part out motor go for $1500. I can't really speak to any of the water cooled motors.
I would also argue that a LS motor from the factory is a special piece considering small package/power output/price. Also I believe that a LS motor built to the high tolerances of a 911 motor would be very special.
Jaynen
Jaynen SuperDork
10/20/17 2:07 p.m.
The one take smoking tire did of the Coyote powered Cayman was pretty sweet
D2W
D2W HalfDork
10/20/17 2:09 p.m.
Other than they couldn't shut the rear hatch. The coyote is an awesome motor though other than its physical size.
Bobzilla
Bobzilla MegaDork
10/20/17 2:28 p.m.
Weight was a thing when GM SBC's used cast iron blocks, heads and intakes. Not so much with aluminum blocks, heads and plastic intake manifolds.
yupididit
yupididit Dork
10/20/17 2:41 p.m.
Basically not an issue in the last 20 years.
Trackmouse
Trackmouse SuperDork
10/20/17 3:31 p.m.
What about a flat six subie engine? Eg33, turbo, all the fun of a 911, still has a boxer, but enormously cheaper to track.
4ucORv0N5LTft3NJXSPAwnRy6Gjz6mV7lJCojtYytFPQzFJyS3An1NBAAV1qbpGo
