D2W
D2W HalfDork
9/25/18 9:37 a.m.
The window regulator on the daughters beetle broke again. When I tried to push the window to the top by hand it was super tight. Anybody ever lube a window track, and if so what did you use?
¯\_(ツ)_/¯
¯\_(ツ)_/¯ UberDork
9/25/18 9:48 a.m.
I clean out the old gunk and use a thin coat of the red Mobil grease that I use on pretty much everything else.
9/25/18 10:36 a.m.
When in doubt, silicone lube is always safe. That's what I'd use.
kazoospec
kazoospec UltraDork
9/25/18 10:42 a.m.
Being a convertible, Miatas get lots of gunk in the window track and need to be cleaned and re-greased fairly often.  This stuff seems to be the "go to" for that job, at least as far as the innanets are concerned.  I've always had good luck with it:
Shin Etsu Grease
9/25/18 11:17 a.m.
I got a can of this just for window tracks!
D2W
D2W HalfDork
9/25/18 1:01 p.m.
Thanks guys.
Cousin_Eddie
Cousin_Eddie HalfDork
9/25/18 2:46 p.m.
Shin Etsu Grease
Yes. A bit expensive but a tube should last for a lifetime.
fNxVfyS7ajgAh0TUwmJa6yoNSjMWECjOkzhXBLXJRStiA395c61VYqq6yD8OAhN6
