BigD
BigD Reader
4/6/12 3:44 p.m.
Posting for a friend who's doing an LS4 Fiero conversion. To make his clutch work, he needs roughly 40mm long flywheel bolts. The longest we can find is 29ish mm used in the CTS-V. No bolt supplier seems to carry these (incl the usual suspects like McMaster). Some have suggested that this isn't actually a metric size but an imperial one but we tried their suggestions and while the diameter is close, the pitch is out to lunch.
Any ideas/sources guys?
iceracer
iceracer SuperDork
4/6/12 5:18 p.m.
Must be a real thick flywheel.
benzbaron
benzbaron Dork
4/6/12 6:04 p.m.
What about getting some m11 all thread and welding a nut on then cut to fit. Not a perfect solution but might work.
stuart in mn
stuart in mn UberDork
4/6/12 6:06 p.m.
For a flywheel you'll need strong bolts, don't scrimp. Have you checked with ARP?
4/6/12 7:08 p.m.
40mm = an inch and a half. Today I bought an M-12 that was 4.5 inches long, granted it was an 8.8 and you want a 12.9 grade, but I can't believe it's that hard.
Maybe I misunderstood the question.
Dan
Taiden
Taiden SuperDork
4/6/12 7:09 p.m.
mcmaster carr
Is it really m11? Or m10. Mc master carries just about everything and I can't even find anything m11 thread.
4/6/12 7:11 p.m.
$1.
http://www.boltdepot.com/Product-Details.aspx?product=6769
Taiden
Taiden SuperDork
4/6/12 7:15 p.m.
mcmaster p/n 98093A761
BigD
BigD Reader
4/6/12 7:27 p.m.
Yup, definitely M11. Even tried calling GM and they said they don't make them anymore and neither does any fastener supplier they know of.
And yeah, these are flywheel bolts so McGyvering anything isn't an option.
We tried ARP but their shortest M11 stud is really long (specifically, the unthreaded part is too long)
Latest news is his clutch maker may be able to offer him clutch plates with a different center (concave) so he can remove/reduce his flywheel spacer.
Knurled
Knurled Dork
4/6/12 8:13 p.m.
Try a head bolt from something?
Head bolts are usually M11 or M9, I am assuming because that helps prevent cheap bastards from using generic fasteners in this critical application. (Hint)
It also means that engines can yield a surprising number of "bucket bolts" that are completely useless.
Taiden
Taiden SuperDork
4/6/12 10:16 p.m.
Can you have a machinist drill and tap them for m12x1.75?
jimbbski
jimbbski Reader
4/6/12 11:30 p.m.
Taiden wrote: Can you have a machinist drill and tap them for m12x1.75?
I agree. Tapping to a larger size is the way to go. And why stay metric. Going to a 1/2 -13 size is much more common and easier to find in a high grade bolt. I bet ARP selll something that you can use.
I suggested going 1/2 inch as well since the diameter of the thread root of the 11mm hole may leave a 12 mm thread not fully formed.
Taiden
Taiden SuperDork
4/6/12 11:33 p.m.
^^ There you go
Zomby Woof
Zomby Woof UltraDork
4/7/12 6:15 a.m.
If you go with 1/2", it's 1/2"-20 you want, not 1/2"-13
44Dwarf
44Dwarf Dork
4/7/12 7:29 a.m.
change to studs? try metric screw and tool in Wakefeild mass. They have it all.
http://www.metricscrew-toolco.com/
iceracer
iceracer SuperDork
4/7/12 10:06 a.m.
I don't find an M11 size listed.
either M10 0r M12
M11 would be very close to 7/16"
did the LS4 use metric flywheel bolts ?
Taiden
Taiden SuperDork
4/7/12 10:08 a.m.
It really bugs me that it's m11. Makes me wonder if the fastener is being measured incorrectly. I noticed that you didn't spec the thread pitch too. Have you taken it to a fastener specialist to get it specced? We have this place in Portland called KL Jack and those guys are crackheads with their fasteners. If Portland Maine has it, someone in Toronto has it.
ditchdigger
ditchdigger Dork
4/7/12 11:48 a.m.
It is M11 for a reason. That way no one can replace them with the wrong spec bolt. In the same way that M12X1.50 thread pitch is very hard to find in regular grade bolts and is the standard for european car wheel fasteners. That way Joe Hamfist the backyard mechanic can't go and use 5.5 class chinese bolts to hold the wheels on the car.
Taiden
Taiden SuperDork
4/7/12 12:50 p.m.
I can understand that reasoning, but it's still awkward.
ditchdigger
ditchdigger Dork
4/7/12 1:50 p.m.
But it is also very smart. You have to respect the engineer that thought it up.
peter
peter Reader
4/7/12 4:14 p.m.
Call Maryland Metric. Their website, marylandmetric.com is completely useless, but they've found me some really oddball bolts before. If they don't have it, it probably doesn't exist. Though I like the tapping-a-new-thread idea.
6FMYOnwzcvGhRXtGuSejHZJXMmle5DDLSMK5W96BUBptUrHkpKkntKQuXA4WUEBC
