Jaynen
Dork
5/27/13 12:48 a.m.
So I normally change the wifes oil the past few times with Rotella T5, this time I grabbed T6 full synthetic. The automatic trans seems to slip a bit sometimes when going from like a neutral to first gear. Besides this it is fine.
I would have thought the trans was using ATF anyway? But it seems to have started coinciding with this recent maintenance.
Any thoughts?
The matrix/vibe auto trans pan has a drain plug just like an oil pan.
I have personally mistakenly drained ATF from the trans instead of the motor oil. It uses Toyota type 4 but m1 atf seems to work.
Double check you have the correct amount of fluid in both the trans and engine. Hopefully it's that simple.
Jaynen
Dork
5/27/13 12:58 p.m.
Good call. That is exactly what I did. Found the oil over full and the ATF way low. Should be fixed properly now
