joey48442
joey48442 UberDork
8/19/12 5:22 p.m.
How many horsepower can a 1.6 stock clutch handle, assuming its new? I'm debating going with a 1.6 clutch for the lighter weight flywheel, but I'm not sure if it will hold up to a supercharged 1.8...,
Joey
Keith
Keith MegaDork
8/19/12 6:40 p.m.
160-ish at the wheels. Probably a better choice to put in an aftermarket lightweight flywheel with a 1.8 clutch instead.
Xceler8x
Xceler8x UltraDork
8/19/12 9:55 p.m.
Keith is being too polite and not suggesting that you get the Flyin Miata happy meal clutch pack. He works there so doesn't want to come across like a shill.
I had a turbo'ed 1.6 and used the 1.8 kit with the lightened flywheel. 13lbs I think. Worked incredibly well. Where the heavy duty 1.6 clutch would slip at 150 hp or so this one held up to possibly 200. I was running 12lbs of boost on a 1.6 if that's any help. Also, I should've gotten the lightest flywheel they offered. I never had a problem with daily driving it with the lighter flywheel.
Keith
Keith MegaDork
8/19/12 10:04 p.m.
It's assumed that you should always buy FM stuff where available The Level 1 clutch is basically able to hold more power than stock engine internals can produce but has nearly stock pedal effort, so it's my choice.
With a supercharger the extra mass of the 13 lb flywheel is handy. They're a bit ornery at idle with the 10 lb.
joey48442
joey48442 UberDork
8/19/12 10:25 p.m.
I'm sure I will upgrade to the happy meal eventually, but I think I'll stick with the stock 1.8 stuff for now, as what I already have is cheapest... Motor will most likely come back out this winter anyway.
Thanks guys!
Joey
joey48442
joey48442 UberDork
8/20/12 7:07 p.m.
Any idea on what a stock (or stock replacement) 1.8 clutch can handle power wide?
Joey
Keith
Keith MegaDork
8/20/12 10:38 p.m.
180-ish.
joey48442
joey48442 UberDork
8/21/12 8:58 a.m.
Keith wrote: 180-ish.
Thanks!
I want a lighter flywheel bad, but this nearly free engine swap and cheap supercharger is getting expensive...
Joey
thatsnowinnebago
thatsnowinnebago Dork
8/21/12 12:51 p.m.
See if a local machine shop will just lighten the stock flywheel
Keith
Keith MegaDork
8/21/12 12:54 p.m.
Not my favorite method, honestly. Flywheel failures end badly, and they spin at engine speed.
IssiPSTbcHuBISwWa4evIIlpU34A8JqWaEjyd3IDjaxF5GKa9Pu8G0XABwAtVLCr
