joey48442
joey48442 UberDork
8/9/12 4:11 p.m.
So, I got a non adjustable powercard for my soon to be supercharged Miata (thanks Mark!) but I cant find any install instructions. Just for the more fancy adjustable model. There are only Six wires on this thing... Also, if I look up the CARB exempt number, its for a MP62, and I have an M45... Will this be an issue?
Joey
Keith
Keith MegaDork
8/9/12 4:52 p.m.
It's only an issue if someone ELSE looks up the CARB exemption! The fueling will probably be fairly close.
Check with Jackson Racing, they should be able to provide the wiring. On a 1.6 (other than 1993 CA models), you'll tap into the two injector signal wires, power and ground. Six wires would imply that it's designed for a 1.8 or 1.6 CA car which have four injector signal wires, I bet you just leave two of them off.
joey48442
joey48442 UberDork
8/9/12 5:07 p.m.
Keith wrote: It's only an issue if someone ELSE looks up the CARB exemption! The fueling will probably be fairly close. Check with Jackson Racing, they should be able to provide the wiring. On a 1.6 (other than 1993 CA models), you'll tap into the two injector signal wires, power and ground. Six wires would imply that it's designed for a 1.8 or 1.6 CA car which have four injector signal wires, I bet you just leave two of them off.
Oh boy... I'll contact jr.
Thanks!
Joey
joey48442
joey48442 UberDork
8/10/12 5:56 a.m.
Well, the guy at moss was a bit snotty. He told me to "read this carefully, the carb unit is not adjustable" which I know, as I said twice that I had a non-adjustable carb model. Oh well.
I think I found a picture that shows how to wire it myself, and it does show 6 wires for the 1.6. So I think I'm good!
Joey
qzSgVjZbD2WeyvrMSBfElnZ6ZIS6vKZI5tHS3BZPoi1WK4xXHbzsDjwyfpqF3ecw
