Woody
Woody Dork
3/20/09 3:04 p.m.
I'm getting ready to order some tires for my 96 Miata.
205/50-15 seems to be the natural choice for track use, and I already have a set ready to go.
For the street, 195/50-15 would be a direct Plus 1 swap up from the stock size of 185/60-15.
However, with another set of 205/50-15's, my alignment wouldn't change when I swap from street to track tires, but the speedometer and final drive ratio would be slightly off, due to the 205's greater circumference.
Is there enough of a difference to matter?
jrw1621
jrw1621 HalfDork
3/20/09 3:22 p.m.
Woody wrote: Is there enough of a difference to matter?
This will tell you exactly how much difference.
http://www.miata.net/garage/tirecalc.html
Personally, I like 205's on the street. The taller side wall takes away some of the harsh ride if a stiff suspension.
billy3esq
billy3esq Dork
3/20/09 3:26 p.m.
It would depend on the specific tires, but my rough calculation puts the circumferential difference between a 195/50/15 and a 205/50/15 at something like 1.7%. That's not going to create noticeable speedo error.
Woody
Woody Dork
3/20/09 3:59 p.m.
This will tell you exactly how much difference. http://www.miata.net/garage/tirecalc.html
Wow, I never saw that before. Thanks.
mistanfo
mistanfo Dork
3/20/09 5:47 p.m.
I think that my Miata's speedo is about 4% optoimistic anyways, so it might not be a bad thing.
Salanis
Salanis SuperDork
3/20/09 6:03 p.m.
Unless I'm mistaken, aren't there subtle differences in tire diameter anyway? Obviously there must be, since tires will get smaller as they wear down.
I was under the impression that even though a 205/50/15 is theoretically bigger than a 195/50/15, in practice there's going to be more variation between tire models within a given size than there will be between sizes.
Keith
Keith SuperDork
3/20/09 6:27 p.m.
Zacktly. That's why, while the tire calculator is cool, I always work from manufacturer spec sheets.
mistanfo's dead on about the Miata speedo as well. They're very optimistic, so running a taller tire is only going to make it more accurate.
Woody
Woody Dork
3/20/09 6:39 p.m.
That settles it. 205/50-15 for road and track.
Buzz Killington
Buzz Killington New Reader
3/20/09 9:16 p.m.
won't matter.
i run 195/55/14s as my snow tires (a bit taller than OE), and don't notice any difference from my 195/50/15 summer/autoX tires, except for a slightly cushier ride.
yUxOhJHIROXJy6DvK8H206Vqa4g4KPejmdgejYYSQlspS3W4qfeBFwfqhIAOx5py
