pinchvalve
pinchvalve SuperDork
4/25/11 12:08 p.m.
Can someone please burn this damn thing to the ground?
The clutch wore out (expected at 95,000+ miles) so I did the swap myself. No problem there, but the electrics were all wonkey. OK, I traced to a bad ground, re-did and the car is happy right?
Wrong. The oil pan rusted though and sprang a leak. Doh! So I order the parts from Tokyo and wait for a week or so and do the swap. Hardest part? Removing the oil filter that was apparently welded, epoxy bonded, bolted, and then superglued to the block by the 5-min oil change place. Doh! Got everything bolted back up and now the car runs fine for a minute, but as soon as it starts to heat up the thing just dies at anything over idle. WTF?!?!?
I suspect the O2 sensor because I unplugged it, then plugged it back in. If something is not making a good connection with a 4-wire O2 sensor, what would be the result on performance?
bluesideup
bluesideup Reader
4/25/11 12:18 p.m.
Try unplugging the o2 sensor to make it stay in open loop and see if it runs fine after warming up. A wonky u2 sensor can do all kinds of bad things. What kind of Mitsubishi? That's Japanese for "teach the neighbor kids bad words".
pinchvalve
4/26/11 1:50 p.m.
Thanks, that's a good idea. Its a Mirage, named because it has only the appearance of being a car. It is in fact, satan's poo.
bluesideup
bluesideup Reader
4/26/11 4:00 p.m.
I have one too, my brother says it's a false impression of a real car. I've been through the whole thing so if you have questions just ask. I might even have parts left over that I need out of my storage.
QijuHRvRfxCtDV5z9uXcqlmgmIlbAoRAhT3hj7OTfcqLW8llDE0cC6lDfcj77GOI
