RoughandReady
RoughandReady HalfDork
6/23/14 12:00 a.m.
Did some brake work on girlfriend's 190 today. Sad part is, the brakes aren't any better, just different. Since we've had it, the car has suffered from a stiff pedal with too little travel. Today I rebuilt the front calipers (one was just about frozen) and we're suffering from a low, squishy pedal. The pedal is high and stiff with the car off, and sinks when the car is on. Maybe something to do with the booster? I know the booster is doing something, since the car is incredibly hard to stop with the booster disconnected.
I've bled the brakes a couple times already (and I'll be the first to admit that I'm not great at bleeding brakes). There doesn't seem to be any sign of a leak, the pedal holds steady and doesn't sink down. That seems to rule out a bad master cylinder too, which my buddy swears is the issue. Everything seems to point to more air in the system, though I don't seem to be getting it when bleeding. I'm lost, and all I can think of is to bleed and bleed until the brakes work as they should.
Two points that may be of interest:
  1. With hard braking, the car pulls left some.
  2. I believe the fluid was overheated yesterday. I'm wondering if there's still some burnt up fluid in the system disturbing the whole affair.
I'm open to any suggestions.
Johnboyjjb
Johnboyjjb Reader
6/23/14 8:29 a.m.
Counter intuitive but if it pulls left look at the right front caliper and hoses.
You may also have a leak with the hose going to your booster.
That's where I'd start. Sounds like two different causes muddying the water.
Lancer007
Lancer007 HalfDork
6/23/14 8:37 a.m.
Rubber sections of the brake lines ballooning? Vacuum leak somewhere?
HappyAndy
HappyAndy UltraDork
6/23/14 8:44 a.m.
Does this car have a diagonal braking system? SAAB c900s do, and pulling to one side is exactly what they do when only one chamber in the MC is working.
It would also be a good idea to check the rubber brake hoses.
iceracer
iceracer PowerDork
6/23/14 10:52 a.m.
What's a 190 ?
RoughandReady
6/24/14 11:59 p.m.
HappyAndy wrote: Does this car have a diagonal braking system? SAAB c900s do, and pulling to one side is exactly what they do when only one chamber in the MC is working. It would also be a good idea to check the rubber brake hoses.
I think you've hit the nail on the head. According to an MB old timer I talked to today, if you look at the front chamber of the MC the wrong way, you'll blow it out while bleeding.
gfjKCwcaDeIBIBY93HVY4ORO7BvZ07TD5oVpAHhbvTHXwKp8E0p0PD9ak3j9gsQu
