pirate
pirate New Reader
11/23/11 4:49 p.m.
Has anyone used the Moroso Spiral flow Mufflers? Opinions? They will be used on a V6 but have very limited space not only for lenght but also diameter. any other options you can suggest?
914Driver SuperDork
11/23/11 6:02 p.m.
What application?
pirate
pirate New Reader
11/23/11 6:22 p.m.
Chevy 3.4 V-6 Stalker with side pipes on each side. Spiral Flow mufflers would be attached directly to the headers with a turn out/down on exit end slanted down about 45 degrees to further quiet exhaust note.
44Dwarf
44Dwarf Dork
11/23/11 6:22 p.m.
I use one on the dwarf it works good but it's not wisper quiet but then again it only has a 4 inch sectoin of straight then a slash cut elbow. Dyno showed no hp drop. it it less noise but i didn't have a db meter at the time. 44
paul
paul Reader
11/23/11 7:06 p.m.
spintech prostreets...
pirate
pirate New Reader
11/27/11 8:15 p.m.
Bump! Anyone? Anyone?
mike
mike Reader
11/27/11 10:22 p.m.
Just looked this up out of interest. It looks like they stuck an old auger in there.
mad_machine
mad_machine SuperDork
11/27/11 10:31 p.m.
I wonder if that helps or hurts flow?
Zomby woof
Zomby woof SuperDork
11/28/11 4:47 a.m.
mad_machine wrote: I wonder if that helps or hurts flow?
Why?
81cpcamaro
81cpcamaro Reader
11/28/11 7:29 a.m.
They do work fairly well. You can save some $$$ and use these: http://www.speedwaymotors.com/Speedway-Auger-Style-Muffler,1736.html I have used these baffles as secondary mufflers in tailpipes, helped knock down the noise level some. Didn't notice any power loss with them.
mad_machine
11/28/11 7:59 a.m.
Why?
most performance mufflers are a perforated (or gasp, louvered) core pipes... they absorb sound without impacting too much on flow. The spiral shape has to affect flow some as the air passing through is sent into a spin.
That said, I wonder if one of those up close to the engine would actually help.. in a turbonator kinda way?
pinchvalve
pinchvalve SuperDork
11/28/11 8:09 a.m.
Out of curiosity, what do other sidepipe-equipped cars use? All those old Corvettes with sidepipes must use something right? And the early Vipers?
Curmudgeon
Curmudgeon SuperDork
11/28/11 8:22 a.m.
Those chrome sidepipes generally came with a slip in style glasspack insert.
Ds4BELsuS9h604iCMknZWILDO310VOQ6G5NLFz1S7BzPkCk2bWOeIhWJzzWeGDVA
