pinchvalve
pinchvalve SuperDork
10/18/11 12:06 p.m.
The rear bearings need replacing on the AW11 MR2, but the BGB shows may SSTs required. Do I really need an oil seal puller, a bearing puller, a control arm puller, and three other pullers just to do this job? Is there a grassroots method?
evildky
evildky Dork
10/18/11 12:25 p.m.
I have not replaced the bearing in my aw11 but a seal puller is handy to have but you can do the same job with a screwdriver or small prybar
I'm nto sure what a "control arm puller" is but I suppose if your going to take the strut assembly off you'll need to pop the tie rod off the knuckle I use a picle fork, or you can leave the tie rod on the knuckle and remove the other end from the inboard mounting thingy (technical term) (I really have no idea what to call that inboard pile of stamped steel bolted to the chassis, that the lca and tie rod bolt to, there a name for that?)
the bearings I suspect can be driven out with a brass puch and a bfh with the assembly still on the car but I could be wrong
ultraclyde
ultraclyde HalfDork
10/18/11 2:11 p.m.
I'll say this for bearing pullers, seal pullers, control arm pullers, etc.....You can usually get by without them but every time I've used them I thought "Good GOD why didn't I do this last time?" The time, frustration, and amount of bodily injury saved by their use is really significant. Mostly for me it makes the difference between feeling like a job was pure hell and hating to see a wrench to thinking, hey, not bad, I really do like this hobby.
Of course, your local parts chain usually has any of these for free rental (or more normally, a fully refundable deposit). NO way I could afford to own all that crap!
fast_eddie_72
fast_eddie_72 Dork
10/18/11 2:15 p.m.
Not sure they're the same, but I kinda think they are - when I had to do my SW20, I took the hub to the Napa with a machine shop, bought the bearing from them and it wasn't too expensive to have them put it in. I messed with it for a good while and decided that was a job I didn't need to do myself.
GBoSYrpi0L3KKVKOXIPpHhaLbvwETcM2aJT8HH9fNTK1Cn0MoLjD54jgwSrmPeai
