dansxr2
dansxr2 Dork
5/20/13 10:38 p.m.
https://docs.google.com/file/d/0B9YltSYEj-5naGVDMjg3eWl2RHc/edit?usp=sharing Datalog
https://docs.google.com/file/d/0B9YltSYEj-5nZTZtLXZBVUFFWGs/edit?usp=sharing Current Tune
dansxr2
dansxr2 Dork
5/26/13 10:09 p.m.
I'm beginning to suspect a bad fuel pump or a regulator.... 10 psi and it'll run to redline no prob, 15psi and 4500-5000 it hits a wall it seems to run out of steam
Swank Force One
Swank Force One MegaDork
5/27/13 12:36 p.m.
Do you have a way to measure fuel pressure? It's entirely possible, but just remember that your VE table did look pretty wonky.
I hear people saying that a big pump will overwhelm the stock regulator. I don't know how plausible it is, but you're probably running with a regulator with over 100k miles, so....
dansxr2
dansxr2 Dork
5/27/13 1:18 p.m.
Know of a challenge friendly regulator thats up to the task?
Swank Force One
5/27/13 1:39 p.m.
You can usually find Aeromotives for $100 or less used, but bear in mind there's some additional cost in fittings and hoses.
I've seen some people using the cheapo Ebay ones with some success, but that's one of those things i prefer to use "name brand" parts for. Aeromotive, AEM, Turbosmart, Fuelab, etc.
I use an Aeromotive 13109 on my car. Got the setup for $75 shipped, had to buy two fittings, sold off 5 i didn't need. (was a KL setup.)
MadScientistMatt
MadScientistMatt UltraDork
5/28/13 9:12 a.m.
It seems to be getting enough fuel, but I'm seeing the MAP driven acceleration enrichement and decel fuel cut false triggering. Try increasing the MAPdot threshold, or putting a fuel filter in the MAP sensor line.
dansxr2
dansxr2 Dork
5/29/13 5:47 p.m.
So I'd like to redo my own Fuel VE and usin g the VE wizard Im not sure where I get these numbers from... The Max HP/Kpa, Torque/Kpa.... Where do I get these #'s from? Im running 460cc Injectors, a GT2871R @15psi on an F2T. redline is 6500. Id like to run~20psi. My AFR'S are not multiplied in. what range should my fuel load be?
MadScientistMatt
5/30/13 7:36 a.m.
Fuel load should be from the most vacuum at idle to the most boost (looks like around 210 kPa, in this case).
Ideally, you'd get the numbers from a dyno on a modified engine, but if it's internally stock, you could scale them up assuming the same torque curve shape as a stock motor.
dean1484
dean1484 UberDork
5/30/13 8:15 a.m.
This might get you started. It was for a 300hp turbo motor that ran well
Obviously use at your own risk!!!!
dansxr2
dansxr2 Dork
5/30/13 12:21 p.m.
Dean can you email me that please?
Swank Force One
5/30/13 12:31 p.m.
Is that table for an F2T or does it not matter?
dean1484
dean1484 UberDork
5/30/13 4:37 p.m.
dansxr2 wrote: Dean can you email me that please?
The whole file / project? of just the screen clip?
dansxr2
dansxr2 Dork
5/30/13 7:03 p.m.
Im just not understanding the range omakes f the #'s used for the Fuel VE... It pulls like a champ til ~ 45-5000 then feels like Italy hitting a wall. I really am unsure what the problem is, but I suspect the Fuel VE map, because if you let of the throttle in high RPM's it smooths out. If there was someone familiar with MegaSquirt that could tune it, I'd gladly do that. But being smack dab in the middle of West Virginia where seemingly nothing other that the big 3 exist with a 4-BarrelCarb makes it increasingly more difficult to figure out.
Swank Force One
5/30/13 9:46 p.m.
Is the wall hard enough that we'd notice it in a video?
dansxr2
dansxr2 Dork
5/30/13 9:50 p.m.
Yes. I'll post tomorrow Ben, good idea
Paul_VR6
Paul_VR6 HalfDork
5/31/13 4:33 a.m.
If you reduce the load and it clears up, it could be blowing spark out. What's your gap and details on the ignition system?
dean1484
dean1484 UberDork
5/31/13 7:32 a.m.
Dan,
Email sent.
The file I sent you is an older tune from a 2.0 firmware so it is probably going to ask for an update to tuner studio.
dansxr2
dansxr2 Dork
5/31/13 8:50 a.m.
its got the stock ignition system with and MSD Blaster 2 Coil, Plugs are OE Replacements at stock Gap Settings. I'll replace with a colder plug, and tighten up the gap. How much should I close it up? I think the stock gap is ~.040
MadScientistMatt
5/31/13 8:54 a.m.
MSD Blaster 2 coils aren't particularly hot unless driven by a 6AL - they were meant to be a step up from 1968 era coils, but on a modern engine are OEM level at best and obsolete at worst.
dansxr2
dansxr2 Dork
5/31/13 8:57 a.m.
Recommended ignition upgrade?
Swank Force One
5/31/13 9:07 a.m.
I have a spare 6A around here somewhere, might be a 6AL. I'll check for you if you're interested.
Ignition really shouldn't be an issue here, though.
Two points, though: If you're not using the blue NGK wires, get a set. If you're not using NGK ZFR7F11s, get them.
I run a .035-.040 gap on my car.
People have taken the stock ignition, even with stock coil and ignitor well into the 300whp range. You aren't there yet.
Did you ever replace that ignitor that was giving you fits at the Challenge? Or have you just left it alone after cleaning it?
dansxr2
dansxr2 Dork
5/31/13 9:12 a.m.
http://s79.photobucket.com/user/dansXR2/media/20130531_060607_zpsfdd5d832.mp4.html Here's a video of the problem.
http://s79.photobucket.com/user/dansXR2/media/20130531_061051_zpscfe50399.mp4.html and another...
dansxr2
dansxr2 Dork
5/31/13 9:14 a.m.
I swapped it out and haven't had an issue since. Let me know about that 6AL
Leafy
Leafy New Reader
5/31/13 9:26 a.m.
Swank Force One wrote: Do you have a way to measure fuel pressure? It's entirely possible, but just remember that your VE table did look pretty wonky. I hear people saying that a big pump will overwhelm the stock regulator. I don't know how plausible it is, but you're probably running with a regulator with over 100k miles, so....
For posterity, an FPR being overwhelmed by a fuel pump would result in E36 M3 for idle quality, because the fuel pressure would be either above the pressure the reg was trying to achieve, fluctuate heavily, or both. But as you flowed more and more fuel out the injectors it would be able to control the fuel pressure better and better.
Swank Force One
5/31/13 9:48 a.m.
Even if you "tuned around" it?
Suppose you're probably right though.
I still think the VE table looks bad.
qZWo1EP7YCeg3RJmq4NazBQUp9JlDtRLd2rU2aridTfBhnZ7A3mQEy1NXfS4bQwV
