rhgore
rhgore New Reader
11/13/13 7:47 p.m.
I just purchased a 1989 Ford Mustang Gt and the temperature gauge is not working. All of the other gauges work on the dash except for the temp gauge. Any ideas on where I should start looking in order to fix it? Thanks in advance.
wlkelley3
wlkelley3 SuperDork
11/13/13 7:56 p.m.
Sending unit? Usually close to the thermostat housing.
JKleiner
JKleiner Reader
11/14/13 5:10 a.m.
The gauge sender is located at the driver's side front of the intake and will have a red with white tracer wire going to it. Disconnect the wire and turn the key to "on" and the gauge should show cold. When you ground the wire and tuirn the key to "on" it should peg hot. If this happens it confirms that the wiring is intact and points to a bad sender; if not it indicates a wiring or instrument cluster problem.
Jeff
Blitzed306
Blitzed306 Reader
11/14/13 6:30 a.m.
JKleiner wrote: The gauge sender is located at the driver's side front of the intake and will have a red with white tracer wire going to it. Disconnect the wire and turn the key to "on" and the gauge should show cold. When you ground the wire and tuirn the key to "on" it should peg hot. If this happens it confirms that the wiring is intact and points to a bad sender; if not it indicates a wiring or instrument cluster problem. Jeff
This is just one more reason why GRM is the best forum on the web
Storz
Storz Dork
11/14/13 6:44 a.m.
Agreed.
rhgore
rhgore New Reader
11/14/13 7:42 a.m.
In reply to JKleiner: I found the sensor and the wire is attached. I will try to ground it and see what happens. Thanks for the response.
rhgore
rhgore New Reader
11/16/13 8:11 p.m.
Did just as you said and the gauge pegged all the way up. Went and purchased a new sending unit and it works like a champ. Thanks a lot for your help.
JKleiner
JKleiner Reader
11/17/13 6:20 a.m.
Yahoo!
Jeff
Me6p07jNmtJAXjoqHZnqztqQfJsfJp4DAWDRkzymU5fmwQPd1HRxnBjRXsY31jwT
