jackleg
jackleg
7/24/13 3:43 a.m.
Just bought a 95 s10 with a freshly rebuilt 350 in it and it was smoking out the drivers side exhaust, so I pulled the valve cover and the intake rocker on the #5 cylinder wasn't moving so I pulled the intake and the lifter has a hole in the bottom of it...Never had a 350 apart like this before...could it just be a lifter or should I just pull the motor and check everything? Any advise is appreciated, thanks.
stan_d
stan_d Dork
7/24/13 6:54 a.m.
Check the oil filter for metal odds are cam was not broken in properly.
81cpcamaro
81cpcamaro HalfDork
7/24/13 7:05 a.m.
Pull the engine and check everything out, that way you will know for sure how the engine is. There is a good bit of metal floating in the oil with that much wear on the lifter. Like Stan said, the cam wasn't broken in properly.
patgizz
patgizz UberDork
7/24/13 7:48 a.m.
indeed. i'd be ready to do a minor overhaul of every bearing plus a cam and lifter set, to the worst of your crank journals are scored.
good reason/excuse to go roller cam too. i pretty much won't build an engine without one anymore if it can be done.
Sultan
Sultan HalfDork
7/24/13 7:51 a.m.
How about a picture of your S10
jackleg
jackleg New Reader
7/24/13 8:11 a.m.
Thanks for the advice guys! I will definitely pull it all apart and check it all out, and I will post pictures as soon as I can figure out how to.. using my phone on here, so not sure how
t6pEcioYjd1xY394LdZXnn68Iw1VVWR4hA3zNSzqNoKrvmNgfIX69noKt1wd6qyz
