Woody
Woody SuperDork
11/15/11 8:56 p.m.
This morning (Tuesday), I went out to the garage and noticed that one of my front tires was almost flat. I checked the pressure and, sure enough, measured only 8 psi.
On Saturday, I checked the pressure on a couple of the cars. This tire was at about 26 and I raised it to 29. On Sunday, I drove the car for about an hour and didn't notice a problem.
So I removed the tire and couldn't find a nail or any other problem. I removed the valve and it looked fine so I put it back in. Then I inflated it to 32 and submerged it in a tub of water. No bubbles anywhere, tread, bead, or valve stem. It has held pressure now for 12 hours. I'm wondering if perhaps the valve pin didn't reseat properly on Saturday when I added air. Does this sound like a reasonable explanation?
nderwater
nderwater SuperDork
11/15/11 9:10 p.m.
My guess is a bad stem - keep an eye on it.
cwaters
cwaters New Reader
11/15/11 9:15 p.m.
I had that happen once. Replaced the valve stem and all was wall thereafter.
benzbaron
benzbaron Dork
11/15/11 9:35 p.m.
I had a little tiny nail in one of my tires and didn't see anything but sure enough it needed a patch.
Woody
Woody SuperDork
11/15/11 9:38 p.m.
No bubbles, though, and it's holding air now.
stuart in mn
stuart in mn SuperDork
11/15/11 9:59 p.m.
I thought you said mystery Fiat. Is it an alloy wheel? I have a couple on my e30 that will mysteriously lose air, but then be okay for weeks or months. I think it's just a case of corrosion on the rim, and I happen to go around a corner a little too fast or hit a bump.
fasted58
fasted58 SuperDork
11/15/11 10:09 p.m.
I've had several alloys lose air/ flats over the years at the bead or stem. A little corrosion of the alloy will do it. I have bead sealer applied on all street alloys now.
The worst case was when I ran on a BFG/ AT, ruined the sidewall.... that berkeleying hurt
Woody
Woody SuperDork
11/15/11 10:11 p.m.
It's an alloy, but it's like new, and again, no bubbles.
Raze
Raze SuperDork
11/16/11 6:54 a.m.
I've had the same thing on a bead, same 4 tires for the last 2 years, had one go flat every 3 weeks, finally had it dismounted/remounted, been fine for the last year...
SlickDizzy
SlickDizzy SuperDork
11/16/11 7:36 a.m.
The 'no bubbles' bit may be true while the wheel is submerged without any load applied, but if it were possible to add some load to the tire as if it were mounted/being driven on, perhaps you would see a different result.
Giant Purple Snorklewacker
11/16/11 8:14 a.m.
Beat the crap out of whichever of your kids is the most likely to be curious enough to play with the valve stem
Woody
Woody SuperDork
11/16/11 8:23 a.m.
Giant Purple Snorklewacker wrote: Beat the crap out of whichever of your kids is the most likely to be curious enough to play with the valve stem
They're in the clear. One is far too young and the other, far too lazy.
iceracer
iceracer SuperDork
11/16/11 9:52 a.m.
My Liberty had three wheels/tires that regularly lost air. Never could find a leak. Just got used to checking weekly or before a trip.
purplepeopleeater
purplepeopleeater Reader
11/16/11 10:17 a.m.
There've been issues with failures in some valve stems from China going south.
Woody
Woody SuperDork
11/16/11 11:38 a.m.
These were mounted by Tire Rack, so I'm pretty sure that the stems are okay. I ran into that problem with trailer tires, though. The stems dry rotted in less than a year.
joeya
joeya New Reader
11/16/11 11:48 a.m.
Check your rims
My Sebring had a very small hair line crack the eye couldnt see and it leaked for years and would drive me crazy!
vUu8cnC7ZZLUwdLgqF01LYaXl3ISW1Pb0KRCxuh6b5JhIOxxOLrXgT7Fp6kadR0V
