Ian F
Ian F MegaDork
10/6/15 8:48 p.m.
In exchange for some free parts, my ex is letting a local tuner shop use her car to develop parts (CAI and Cat-back, I think). They posted a base-line dyno run:
http://engineering.mishimoto.com/2015/10/mishimoto-dyno-tests-a-2016-nd-miata/
Fueled by Caffeine
Fueled by Caffeine MegaDork
10/6/15 9:15 p.m.
Torquey
johnp2
johnp2 Reader
10/6/15 9:34 p.m.
Hey I work there. Hey that's the blog I work on. Hehe. Please extend our appreciation for the vehicle use.
We are working on an intake and catch can system to start. Should be interesting.
KyAllroad
KyAllroad SuperDork
10/6/15 10:22 p.m.
I know the ND is the "spiritual successor" and "all about balance" and all that, but I have an NA and while it's fine. It desperately wants 50% more hp. Not 10 more.
Bruce
Bruce MegaDork
10/6/15 10:26 p.m.
KyAllroad wrote: I know the ND is the "spiritual successor" and "all about balance" and all that, but I have an NA and while it's fine. It desperately wants 50% more hp. Not 10 more.
It's about how that power is delivered, hence the wide torque curve.
Also to fix the lack of power in your NA:
https://www.flyinmiata.com/fm-ii-turbo-system-na6-chassis.html
MCarp22
MCarp22 Dork
10/6/15 10:48 p.m.
The ND has something like 22hp and 40 ft/lbs over your NA. It'd be like having a M45 supercharger.
Driven5
Driven5 Dork
10/6/15 11:02 p.m.
In reply to KyAllroad:
How much power would you have to add to your NA, from stock, to get down to a 14.5 second 1/4 mile? Regardless of peak numbers on a spec sheet, that's the real world power difference between the two.
AntiArrhythmic
AntiArrhythmic New Reader
10/7/15 12:59 a.m.
I'm trying to understand the low power output. The torque curve is beautiful, but doesn't this thing have 11:1 compression? I just feel that a 2.0L with that compression should make a lot more horsepower.
MCarp22
MCarp22 Dork
10/7/15 5:48 a.m.
AntiArrhythmic wrote: I'm trying to understand the low power output. The torque curve is beautiful, but doesn't this thing have 11:1 compression? I just feel that a 2.0L with that compression should make a lot more horsepower.
13:1, but it appears to be tuned for low end. Nobody in the USA gives a E36 M3 if it makes power up high if it is perceived as being "gutless" (like the FR-S). The average person will drive this, feel the torque below 4000 or so (they're scared to redline it! ) and think "wow this is more powerful than I expected! "
Enthusiasts love bolt-ons and there should be some easy power to find, perhaps in the ECU tune.
mr2peak
mr2peak Dork
10/7/15 6:07 a.m.
I hope it's easy to tune. 77.5hp/liter doesn't sound like a sports car engine these days.
neon4891
neon4891 MegaDork
10/7/15 7:17 a.m.
Keep in mind that is rear wheel #'s, It has already had it's driveline loss.
RossD
RossD UltimaDork
10/7/15 7:25 a.m.
142 lb-ft and 128 whp for those who didn't watch the video.
Swank Force One
Swank Force One MegaDork
10/7/15 7:34 a.m.
It'll be ok, everyone. Big gains are being seen with a tune, and we can always opt to focus on how the car performs, and not numbers on paper in the meantime.
RossD
RossD UltimaDork
10/7/15 7:41 a.m.
Tell me again whats the deal with the Skyactiv engine? Just high compression? Any fancy cam stuff?
alfadriver
alfadriver UltimaDork
10/7/15 7:42 a.m.
mr2peak wrote: I hope it's easy to tune. 77.5hp/liter doesn't sound like a sports car engine these days.
It's a pretty good possibility that Mazda understands how their customer uses this car- to the point where peak power (which is unlikely to be used that often) can be sacrificed for a broad usable power band (used all the time).
And that when a stopwatch is used, this car ends up faster than a car with a better power/weight ratio.
Sometimes, you guys fall too easily into the numbers battle that marketing guys bait you with.
Ian F
Ian F MegaDork
10/7/15 7:43 a.m.
She finds the car to feel more "peppy" than her 2003 MCS which has a few minor bolt-on mods (15% pulley, intake and JCW cat-back), despite the fact the MINI has more power. The MINI is probably ultimately faster, but you have to rev it out to make it happen.
When I drove the car a couple of weeks ago, it definitely surprised me.
Tyler H
Tyler H SuperDork
10/7/15 7:46 a.m.
RossD wrote: Tell me again whats the deal with the Skyactiv engine? Just high compression? Any fancy cam stuff?
It's marketing speak for "Let's add lightness."
tuna55
tuna55 MegaDork
10/7/15 8:01 a.m.
It's a pretty good possibility that Mazda understands how their customer uses this car- to the point where peak power (which is unlikely to be used that often) can be sacrificed for a broad usable power band (used all the time). And that when a stopwatch is used, this car ends up faster than a car with a better power/weight ratio. Sometimes, you guys fall too easily into the numbers battle that marketing guys bait you with.
Mid 6s second 0-60 and mid 14s 1/4 mile is not slow. I am impressed. Wasn't an NA closer to 9s 0-60 and 16-17s 1/4 mile? Incredible difference.
Harvey
Harvey Dork
10/7/15 8:26 a.m.
Guuuyyyyssss, why doesn't it have 200whp?! So disappointed...
Flight Service
Flight Service MegaDork
10/7/15 8:39 a.m.
I think it is a gift. It is light enough, and appears to be, tight enough to handle like, well, a Miata and it has a great foundation for an engine.
Worse comes to worse, swap it for a EcoBoost 2.0. There seems to be enough room under the hood.
Nathan JansenvanDoorn
Nathan JansenvanDoorn Dork
10/7/15 8:41 a.m.
Same(ish) performance as the Fiesta ST 1.6t that everybody loves. Pretty amazing if you ask me: what did a stock 5.0 fox body run again? Remember when they were fast?
johnp2
johnp2 Reader
10/7/15 8:47 a.m.
RossD wrote: 142 lb-ft and 128 whp for those who didn't watch the video.
Thanks Ross. Keep in mind there is some driveline loss with the Dynapack. We also have a Dynojet, which makes for a slightly more exciting event due to the rollers. That being said, the DynaPack is a nice tool and makes the process much quicker due to its mobility.
If anyone would like any specific images of certain components, please shoot me a PM and I will snap a shot.
-John
T.J.
T.J. UltimaDork
10/7/15 8:53 a.m.
Wait, a stock ND is a mid 6 second 0-60 car and all I hear is that it is underpowered? That is marvelous. I think my 2005 Mazdaspeed Miata has something about the same 0-60 and I don't complain about lack of power. I only complain about the low redline and the gearing.
RX8driver
RX8driver New Reader
10/7/15 8:56 a.m.
Brian Goodwin's been working on a couple over on his mazdatalk forum, posting dyno numbers with various combinations of parts and tuning.
Ian F
Ian F MegaDork
10/7/15 8:57 a.m.
All I can say is after driving one it doesn't feel underpowered... of course, compared to the vehicles I own, most cars don't feel underpowered...
hLn1L6mIOP3G385BmdYPSxWVDblxcFaGzKS0wAB5eSNAuS5jC5SUWjD6Z0ln2Bgo
