frenchyd
frenchyd Dork
12/23/17 4:46 p.m.
In reply to alfadriver :
there is a website to find E85 and if you look it’s everywhere.  You don’t need to go to that extreme  (straight E85 )  a gallon mixed with a 1/2 a tank will give you somewhere around 15% alcohol  which will run on most cars made since 2001 just fine.   at a minimum it will clean your valves and injectors and go a long way to reducing deposits in the combustion chamber
alfadriver
alfadriver MegaDork
12/23/17 5:03 p.m.
In reply to frenchyd :
Except an early Miata isn’t that happy with more than E20, since it’s an early controller.
And the fuel choices in California are limited.
I get that you love ethanol, but it’s not the answer for an early California answer.
Brian
Brian UltraDork
12/24/17 1:16 a.m.
straight E85 will cause a CEL on an OBDII car.  It comes up as running too lean.
frenchyd
frenchyd Dork
12/24/17 4:21 p.m.
In reply to Brian :
One gallon of E85 to a1/2  tank of Regular E10 unleaded
 this is the third time I’ve written it
alfadriver
alfadriver MegaDork
12/24/17 6:34 p.m.
And that would still not have solved the OP’s problem.
frenchyd
frenchyd Dork
12/25/17 3:52 p.m.
It might,   But you could be right too,  it might not.   Minnesota stopped smog checking a decade ago
So the old tricks I used to get a dirty car to pass might not work.
alfadriver
alfadriver MegaDork
12/26/17 8:52 a.m.
No, it would not. The cheap catalyst was largely not doing what it should do, and fuel would make no difference to the test that was done.
This isn’t the old sniffer test run in Minnesota, which was largely a good running engine w/o a catalyst. This is a complete, but old, emissions system target.
zZsqfSUmEAMKCSDX3AJfCfwZQCrU0bMVPCcehdTGQSN6HH2ibOPGYLm5GrUa8wg1
