I'll pay shipping/deposit. Located in southern California. I have evil plans for my xjr and I need to remove the pulley.
Now there's a new twist...
I may need to borrow the same eaton supercharger tool when yupididit is done with it!
akylekoz wrote: I can get the part number tomorrow if needed. Unless you are sure it will work.
I can wait for the part number. Don't want to jump the gun.
Might want to look at a power steering pump puller, they come in a number of different sizes and styles.
Paul B
I've got the ZZP Pulley Tool, which should work for both of you, provided that the snout/shaft has a drilled and threaded end. All the GM Eaton blowers have this, but I don't know about the Jag. You can borrow it for the cost of shipping; it should fit in a medium USPS flat rate box if I recall correctly. Send me a PM!
I agree, that looks like the ford/chevy power steering pump pulley kit will take care of it. The local parts store will loan you one.
That looks like the same one I have. Same deal if someone needs it. Pay for shipping and send it back.
Will wrote: I just use a regular 2-jaw pulley puller on my M90. I didn't even know there was a special tool.
I'm only familiar with the M45 on MINI's, but everyone I've heard from who has tried to use a 2-jaw puller has destroyed the pulley. Sometimes taking the shaft with it.
The one FooBag has is the common style I see, used with a standard threaded gear puller. The one I have is different, but specific to the R53 standard diameter pulley.
I can't see how a GM P/S & alternator pulley puller would grab the s/c pulley correctly.
