aussiesmg
aussiesmg SuperDork
8/1/11 7:50 p.m.
Young neighbor (16) asked me if I can help him find the rear frame stubbers for his 98 Firebird V6.
Anybody got a pair at GRM prices?
Feedyurhed
Feedyurhed HalfDork
8/1/11 9:28 p.m.
I must be out of the loop but what's a rear frame stubber?
mad_machine
mad_machine SuperDork
8/1/11 9:29 p.m.
I am puzzled too. I am heading to the junkyard tomarrow.. if I know what to look for...
Aeromoto
Aeromoto New Reader
8/1/11 11:59 p.m.
Subframe connectors?
aussiesmg
aussiesmg SuperDork
8/2/11 7:28 a.m.
Those are his words, I will have to check what he is seeking, I am not a 4th gen guy so I guessed it was something I didn't know about either
BoneYard_Racing
BoneYard_Racing Reader
8/2/11 7:43 a.m.
Bump stops maybe?
oldtin
oldtin Dork
8/2/11 8:03 a.m.
snubber - as in rear bump stops would be my guess too
Aeromoto
Aeromoto New Reader
8/2/11 8:12 a.m.
The rear of a 4th gen F body is pretty much the same as a 3rd gen
RossD
RossD SuperDork
8/2/11 8:21 a.m.
RockAuto.com has parts for cheap but it doesn't show a stubber. There are pictures and maybe you can figure out what RA calls them.
914Driver SuperDork
8/2/11 8:58 a.m.
http://www.energysuspension.com/
NOHOME HalfDork
8/2/11 11:24 a.m.
pinion snubber perhaps? The doinkus aboe the pinion?
aussiesmg
aussiesmg SuperDork
8/2/11 9:47 p.m.
I doubt that he indicated there was one missing from each side.
I haven't caught up with him yet to clarify though
novaderrik
novaderrik Dork
8/2/11 9:49 p.m.
i think there is a snubber on top of each axle where it would contact the frame rail, just inboard of the brakes.
hrdlydangerous
hrdlydangerous Reader
8/2/11 10:29 p.m.
The car usas a torque arm so a pinion snubber isn't needed. He probably means the bump stops. They're located on the frame rail above the axle and usually dry rot and fall off so you probably won't find a decent used set. I cut mine off in order to fit 11" wheels. They're not really a critical component
mad_machine
8/2/11 10:29 p.m.
I wonder if this is like the mispelling/mispronounciation of Bumper I keep seeing online... "bumber"
Intead it is "stubber" instead of "Snubber"
novaderrik
novaderrik Dork
8/3/11 1:58 a.m.
mad_machine wrote: I wonder if this is like the mispelling/mispronounciation of Bumper I keep seeing online... "bumber" Intead it is "stubber" instead of "Snubber"
could be a regional dialect, too.
fasted58
fasted58 Dork
8/3/11 2:19 a.m.
you's see, I needs this here stubber
Nitroracer
Nitroracer SuperDork
8/3/11 5:37 a.m.
I replaced the rear bump stops on my 98' with some $20 energy suspension parts meant for a jeep. I had to trim the metal on the car, but it was worth doing. The car would bottom out pretty often and make a nasty thud.
http://www.ls1tech.com/forums/suspension-brakes/1385437-jeep-bump-stop-mod-sh-t-simple-approach.html
http://www.ls1tech.com/forums/suspension-brakes/1137705-finally-upgrade-crap-factory-bump-stops.html
aussiesmg
aussiesmg SuperDork
8/3/11 7:57 p.m.
That was it, he is very grateful and hopefully a new member
i8IcJ3Hj55G3SDsWg6Dj7VHcmNhrJ9Kry0s7bCYB76Df7Xwh6N91lEtjS5H3RCzZ
