EvanB
EvanB SuperDork
12/12/11 1:05 p.m.
More pictures here: http://imgur.com/a/Rc5Nv
Nitroracer
Nitroracer SuperDork
12/12/11 1:16 p.m.
Inspiration
http://forums.vwvortex.com/showthread.php?5014051-Lifted-Subaru-s-DIR-or-DIW
http://forums.vwvortex.com/showthread.php?5460638-The-Lifted-Wagons-Thread
driver109x
driver109x HalfDork
12/12/11 4:37 p.m.
Yessss to all of the above...
ProDarwin
ProDarwin Dork
12/12/11 4:59 p.m.
Gearheadotaku wrote: Really though, most rally cars don't sit up that high, just have longer suspension travel. Safari (Pari-Dakar) would sit higher. +1 for roof rack, lights, etc. Just add stock size or wider (not taller) knobbies and rally flaps.
Truth.
I rally-xed mine on 1" shorter than stock tires. The car already sits up pretty high...
I do highly recommend this sport... when you no longer care about the car.
CarKid1989
CarKid1989 Dork
12/12/11 5:11 p.m.
Twin_Cam wrote: I've often thought of doing the same thing. But putting taller tires on a Saturd would make it, amazingly, even slower.
I little bigger tire could not make it THAT much slower.
belteshazzar
belteshazzar SuperDork
12/12/11 5:18 p.m.
yeah. slower than what.
CarKid1989
CarKid1989 Dork
12/12/11 5:20 p.m.
93EXCivic wrote: I think it looks cool but I don't see any purpose in it. Are you planning on using it for anything where you need the extra height?
Its purely for looks. Well actually, not for performance or anything but the Saturn goes through everything. Its been over curbs, through everything that comes its way. Not abusing it or anything but it just happens to do everything. Lowering it would be fun i would just have to cut out the hooning and drive like an adult.
"Its a Saturn" we like to say. Can do it all
CarKid1989
CarKid1989 Dork
12/13/11 10:40 p.m.
ok so by my quick looking on the car i feel a spacer on the struts would not work in the front due to the sway bar mounting.
A spacer lift between the body and subframes would most likely work. Rear would be easy might not even need to lengthen the brake lines. Front would be trickier not too sure on that one yet.
JTSBHAgWTmOc1huBTZJIO23TAvIKdEz10oUbB0ooQT7E2MQMCxynNfWhVJvMg4Rp
