John Welsh
John Welsh MegaDork
11/15/17 7:35 a.m.
logdog said:
Do any of the apps get you into ABS or SRS modules?
Torque Pro does not give me these.
mazdeuce - Seth
mazdeuce - Seth MegaDork
11/15/17 7:52 a.m.
I don't know know of any phone based scanner that does ABS/SRS, but if someone knows of one I'd be very thankful.
John Welsh
John Welsh MegaDork
11/15/17 8:23 a.m.
I have found that my O'reily's location has a much better "free scanner" service than the others.  They have read SRS and ABS codes for me.
hotchocolate
hotchocolate Reader
11/16/17 8:52 p.m.
John Welsh said:
Torque app for Prius
Thank you!
Hal
Hal UltraDork
11/17/17 2:38 p.m.
I am planning on using Torque Pro with the Active OBD plug in to get some Subaru specific info.  Torque Pro will be running on an Android tablet that I also use for navigation.
What are your recommendations for a bluetooth adapter?  Prices seem to be all over the place from $3 to $50.
John Welsh
John Welsh MegaDork
11/17/17 4:19 p.m.
This $13 Bluetooth adapter will work fine.  You want this newer small size.  The older version (which I have too) is bulky on some car placements.  On my Prius the big size is easy to knock loose with my right foot since the plug is over the accelerator peddle.  The blue, small size is perfect.
Hal
Hal UltraDork
11/17/17 9:36 p.m.
In reply to John Welsh :
Thanks.  Order has been placed.
Stanger2000
Stanger2000 New Reader
11/20/17 8:27 a.m.
I have one of those mini blue tooth adapters along with Torque app but it does not work with certain cars for some reason.  I've used it with success on an E36 M3, '05 Taurus, MKIV Jetta and others.  However it never paired itself to a '00 Mustang or an '02 Chrysler minivan, strange.   I ended up buying this scanner off eBay for $60 advertised as new and it's worked on everything and anything I hook it up to and does ABS as well.  They usually run a coupon for it for  $99 but best bet is to look around online and find something used for a deal.  I think it's more than good enough for my use (non professionally).
SRS scanners are completely different animals I think, and typically you won't find these 'everyday' readers are able to support SRS systems as far as I know at least.
John Welsh
John Welsh MegaDork
11/20/17 8:52 a.m.
I have in fact used a my small blue device on a 2003 Subaru Legacy.  That might mean it will work on your 2015 Subaru??
XtfKqjXhSjYDoD35Hk5IEihnEh6HlMLk6OoWth3jI9BcTgMwl4NhBwjR0QfoVqfi
