racer_ace
racer_ace New Reader
8/3/09 11:36 p.m.
Which type of silicone would you reccomend for use with a regular gasket when installing a water pump on an RX-7? The ultra high temp Orangey Permatex stuff or the normal, lower temp Blue stuff?
Thanks,
Ray
Osterkraut
Osterkraut Dork
8/3/09 11:44 p.m.
BOTH!
jhaas
jhaas New Reader
8/4/09 12:06 a.m.
As a Tennesse Alumni I saw this comin a mile away...
Here is the 'bird' we gave Florida as we drove across the border for the $2007 challenge...
oh, the blue stuff
MrJoshua
MrJoshua SuperDork
8/4/09 12:15 a.m.
Yeah, hood latch boy, looks like the car and and your "Tennessee pogo stick" you keep in the back, know whats really going on.
Nashco
Nashco SuperDork
8/4/09 12:17 a.m.
I use ultra black kind of like zip ties (it works for everything!) but technically ultra grey is probably "best" for a water pump when not using a gasket. Don't take my word for it, read up:
http://www.permatex.com/products/Automotive/automotive_gasketing/gasket_makers.htm
Bryce
914Driver SuperDork
8/4/09 6:09 a.m.
Gray.
Raze
Raze Reader
8/4/09 6:54 a.m.
914Driver wrote: Grey.
Fixed
914Driver SuperDork
8/4/09 10:17 a.m.
Color/Colour.
Gray/Grey.
Gay.
Junkyard_Dog
Junkyard_Dog Reader
8/4/09 10:28 a.m.
Hondabond
alfadriver
alfadriver HalfDork
8/4/09 10:43 a.m.
Nashco wrote: I use ultra black kind of like zip ties (it works for everything!) but technically ultra grey is probably "best" for a water pump when not using a gasket. Don't take my word for it, read up: http://www.permatex.com/products/Automotive/automotive_gasketing/gasket_makers.htm Bryce
+1. The only real gaskets on our challege Spider was the head gasket and valve cover gaskets. All the rest were the gray stuff- front cover, lower and upper oil pan, intake, etc.
Use a very small bead (the trigger handle helps), hand tighten, wait 10min, and then fully torque. By letting it partially set, it seems to work a little better.
E
Raze
Raze Reader
8/4/09 11:12 a.m.
914Driver wrote: Color/Colour. Gray/Grey. Gay/Gey.
Fixed again...
maroon92
maroon92 SuperDork
8/4/09 11:36 a.m.
guys, its spelled Ghey.
JmfnB
JmfnB SuperDork
8/4/09 11:38 a.m.
And you know because of...
Too easy.
EricM
EricM HalfDork
8/4/09 11:41 a.m.
Um the colors for ILLINOIS are Navy and Orange. SO use the Navy one.
amg_rx7
amg_rx7 Reader
8/4/09 3:55 p.m.
I'd just buy the factory gasket. Works great and lasts forever and not to pricey.
DILYSI Dave
DILYSI Dave SuperDork
8/4/09 4:37 p.m.
Junkyard_Dog wrote: Hondabond
+1. It's the best Grey/Gray RTV ever.
tincetti
tincetti None
8/4/09 5:24 p.m.
Red Loctite..............
Twin_Cam
Twin_Cam Dork
8/4/09 5:44 p.m.
Another vote for Hondabond. That stuff rocks.
racer_ace
8/4/09 8:03 p.m.
OK. Grey it is. ...did not mean to start a ruckus with the title
racer_ace
8/4/09 8:10 p.m.
In reply to amg_rx7:
I read a article on replacing a 2nd Gen RX-7 water pump which reccomened using the stock gaskets and silicone. Is this a bad idea?
aussiesmg
aussiesmg Dork
8/4/09 9:18 p.m.
Use the silicone which can handle the extreme heat of a rotary, much higher temps than a boinger
MrJoshua
MrJoshua SuperDork
8/4/09 11:28 p.m.
I used stock gaskets no silicone for my 2nd gen 7. No leaks!
amg_rx7
amg_rx7 Reader
8/5/09 12:07 p.m.
racer_ace wrote: In reply to amg_rx7: I read a article on replacing a 2nd Gen RX-7 water pump which reccomened using the stock gaskets and silicone. Is this a bad idea?
You don't need silicon if you use the stock gasket. I've never had a WP gasket leak in any of my RX7s.
RexSeven
RexSeven HalfDork
8/5/09 3:57 p.m.
When you guys talk about the stock gaskets sealing perfectly, are we talking the asbestos gaskets or the non-asbestos gaskets? I got some non-asbestos throttle body and intake manifold gaskets for my RX-7s and was planning to use the Permatex copper-colored silicone to seal it all up.
rvuv01nq9QPKv6oGmYJMGWkedJvVj2LdC9e2IHmnT763FDWsIUZQzeSWBh8b6Zp1
