nickleone
nickleone New Reader
1/19/09 10:53 a.m.
What are you using in your parts washers? Nick
Grtechguy
Grtechguy SuperDork
1/19/09 11:25 a.m.
parts washer?
I have one? where?
GameboyRMH SuperDork
1/19/09 11:31 a.m.
I think "parts washer" is fancy talk for paper towels, brake cleaner, and the sharp scrapey thing (old screwdriver?) we use to clean parts.
John Brown
John Brown SuperDork
1/19/09 11:42 a.m.
I had two, one with NAPA parts cleaner one with diluted Castrol Greased Lightning Purple cleaner.
The NAPA used the pump and the other basin did not have one. I can not say for certain that the Purple cleaner will work in a pump enviroment but it cleans the crap out of GREASY parts.
Gearhead_42
Gearhead_42 HalfDork
1/19/09 11:45 a.m.
I attempted to create my own cleaner using water diluted industrial degreaser.
Attempted. It sucked for anything heavier than motor oil.
I'm switching it over to mineral spirits in the spring, disposal be damned...
44Dwarf
44Dwarf Reader
1/19/09 12:09 p.m.
Super Agitene. from Granger's it about $55 for 5 gallon bucket.
44dwarf
porksboy
porksboy HalfDork
1/19/09 12:22 p.m.
I use mineral spirits. As for recycling my local dump has a seperate bowser for other petrolium products other than motor oil or anti freeze.
I tried various things like Purple Power and Greased Lightning but they left aluminum oxide corrosion on aluminum parts and steel and cast iron would flash rust.
I tried to get a service like Safety Clean but they arent interested in the consumer level, They want a monthly service contract at a shop and I dont do enough to warrant that. Besides I thing my parts washer is a "reclaimed" washer from a "major contract opperator".
Dr. Hess
Dr. Hess SuperDork
1/19/09 1:33 p.m.
What? #2 DIesel Oil not good enough for you?
Kramer
Kramer Reader
1/19/09 2:00 p.m.
Stoddard Solvent, if I could still get it.
Otherwise, Gunk Super Concentrate, mixed in kerosene.
ncjay
ncjay New Reader
1/19/09 5:04 p.m.
A few gallons of parts cleaner from the auto parts store and a few gallons of kerosene. I really should clean it out and put some new stuff in there.
maroon92
maroon92 SuperDork
1/19/09 5:32 p.m.
GASOLINE IS A BAD IDEA!
someone local to me had gasoline in their parts washer and some metal on metal contact caused a spark that lit his garage up like the 4th of july.
I use Kerosene...much higher flash point.
RXBeetle
RXBeetle New Reader
1/19/09 5:42 p.m.
Mineral spirits. I have a 5 gal. steel bucket I welded a strainer pickup to the bottom of and 3 legs. I have an old fuel pump and a large hydraulic filter on there with a hose. I throw my parts in a rubbermaid tub and scrub with a brush and the hose from my pumping station. When I'm all done I just pour the mineral spirits back in the bucket and seal it up. Cost me $0, just stuff I had laying around.
porksboy
porksboy HalfDork
1/19/09 6:04 p.m.
Damn thats a good idea with the filter, why the berkeley didnt I think of that? My mineral spirits are getting a bit funky and I need to change it. I think a big fuel filter from the parts store oughta do it. When the flow drops off its time to change.
a99Rk2DFw3zczrD4BFOwhxZ5A5KFATdc8s19NWwYmC5T1wmCsRtbZgBrFCMmXN85
