Noddaz
Noddaz PowerDork
4/6/23 11:39 a.m.
How about an old fashioned repair.  Grind to good metal and solder that $#@&^%.
NOHOME MegaDork
4/6/23 11:57 a.m.
That is actually a good idea since it can be done with a solder gun and no flame.
I found a low temp silver solder that I use to attach fittings to NiCop lines. Says you can do it with a lighter. All I know is that it requires no flux and it sticks to stuff that plumbing solder falls off of.
02Pilot
02Pilot PowerDork
4/8/23 9:26 a.m.
Talked to my indy yesterday, and we agreed that an aluminum pan is the way to go. I'm checking local yards for a used one, and I've got new gasket, bolt set, and OQS on order. Once I've accumulated everything, I'll get it flatbedded down to him; I don't have a lift here, and doing in on my back in the driveway just seems like a recipe for discomfort. Plus, the low-torque aluminum stretch bolts make me nervous. He told me they break all the time, even without disturbance - they had a car come in recently with a dozen of them still in place but broken and needing to be extracted. Better him than me.
4/8/23 9:49 a.m.
In reply to 02Pilot :
Oh yeah, they break all the time in service.   Fortunately, because they break in tension and not because they were bottomed out, and they don't corrode to the magnesium block (the reason why BMW is afraid to use steel), they just spin out with your fingers.
Torque is something like 4 N-m plus 90 degrees.  They don't make it to 5 N-m, that 90 degrees is all stretch.
Slippery
Slippery PowerDork
4/8/23 10:29 a.m.
I think this is what you need.
Contradiction
Contradiction HalfDork
4/12/23 1:50 a.m.
Way back in College I had a 92 Ford Crown Vic as a winter beater.  It had a rusty oil pan (apparently a known problem for these cars) and it was leaking like a seive.  I think on the drive from Upper Michigan to Grand Rapids, MI I put in like 4 quarts of oil.  I had to top it off every couple of days after I got there.
I was broke and had nothing to lose so I drained the oil, cleaned the pan as best as I could with degreaser, and put a nice big fat wad of JB Weld or some similar metal epoxy product on it.  I let it dry for a few hours and filled it with oil again and prepared for it to fall off any day after.
Somehow it stopped the leak completely and it was totally fine for MONTHS!!!!  I think about 6 months later I had finally scrounged together enough money to have a shop replace the oil pan when I had to bring it to a mechanic for some other work.
02Pilot
02Pilot PowerDork
4/26/23 9:19 a.m.
Car is done. I'm told there were really no issues with using the aluminum auto pan, and everything in the bottom of the engine looked nice and clean. For five hours of labor and the cost of parts (the biggest of which was the new OQS), I'm happy to know it's more or less permanently resolved.
Slippery
Slippery PowerDork
4/26/23 9:32 a.m.
Awesome! Now hurry up and go drive on those salty roads before all the snow goes away! :)
Spartina
Spartina New Reader
2/8/25 12:07 p.m.
That's good news [ok I'm a couple of years late!]
On topic!
I have a British Sylva "kit" car  a MoJo,  [https://www.totalkitcar.com/2016/04/07/the-sylva-marque-changes-hands/] which I drove from Manby Lincolnshire to Tayport in Scotland 360 plus miles, the first time  I had driven ANY [kit] car, which entailed having my ass 2" from the tarmac!
Anyway we get to the Forth Road bridge tolls ..
Forth Bridges Visitor Guide - Accommodation, Things To Do & More |  VisitScotland
...and as I throw more money at the toll operator I quip "wow someones burning oil badly" and he says "Aye it's you an yer reekit!"
Yep, a porus sump, so an emergency pull into the service station and some [!] of Mobil one finest [well it was then] 10x60 and back on the road, no more issues, in fact I in a act of wanton exuberation I actually ran it to the rev limiter a couple of times [ it's dark now and nice flash out the exhaust doing it].
So a couple of days later in the car club started the incredible job of removing the sump pan, due to the nature of the engine location, behind the seats, and the suspension layout de-dion type, even under a pit it was a NIGHTMARE! The sump was repaired by braising. More nightmare getting it back on AND not leaking from seals.
39 years on I still have it. This was Jeremy Phillips own Mojo.
On a good weather day with the tyres warm enough and finding good traction from the road surface it can still accelerate through the gears and push your head back over the seatback onto the roll cage....
And that's what it's about.
crdcxBhp6O38NCo6ftKFwwHSDdHrO98ls8qCYuofitBoIuOOzhskdiGLIf4AF9qi
